It would be highly unlikely that there would be any difference. The front suspension design is the same, is it not? The rear suspension uses eyelets on the lower end of the dampers, yes? If so, then go right ahead.
Look at photos of R32 rear ends and the suspension units that you would consider using, then go look at what you've actually got on the car.
  • Like 1
https://www.sau.com.au/forums/topic/479553-r32-gte/#findComment-7922767
