(1993 skyline gtr) hey guys I know theres a million threads on 4wd not working but this ones a little weird. bought my car had no lights on dash but knew right away the 4wd wasn't working,(snow on ground easy to tell).  I traced it down to the g sensor code 13,  no big deal up to this point 4wd fixed. I got curious and pulled my 4wd fuse and turned the car on. I still have no 4wd light on my dash when I know my other gtr's in the past have put a light on dash with fuse out. ive been on the computer for 5 hours trying to find out why I cant get my light to come up on my dash even witht he 4wd fuse pulled.  hopefully someone can give some input, I live in Canada in an area where not much help with atessa system issues. need the boys to pull through here!
ill take the dash apart tonight and see maybe the light burnt out, or taken out by previous owner before the sale. should have checked the 4wd before I bought the car but oh well. will post a fix if I figure it out. I did fix the 4wd with a new g sensor.
Problem fixed, I took off the gauge cluster and switched the oil pressure bulb and 4wd bulb and right away the 4wd light came on(I have the fuse pulled for 4wd cause I already fixed the actual 4wd issue even with burnt out light. Atessa flashed a code 13 easy fix g sensor. If need any help getting your cluster off or trouble shooting 4wd let me know I just did 6 hours of research on the site today and learnt a lot. Thanks guys for all the write ups I wouldn’t own this car without this site?
  • Like 3
man that's  a great help I was gunna ask if someone can point me in the direction of some new bulbs. I didn't find the cluster that hard to remove at all so I just want to replace all my warning bulbs for now with standard oem ones if I can get them.  I like keeping the old girl as original as possible. My lights are super bright at night(cluster) I only think the bulb burnt out cause the 4wd light had been on for a very long time. again I want to replace all my warning bulbs in the cluster. if anyone knows where I can get standard bulbs to replace the oem warning signals that would be a great help!!
I have no issues with throwing the led ones in for now as again no problem taking out cluster.  will the led lights work in the warning bulb locations without issue?
Edited by MoMnDadGTR
its a 93 gtr but yeah same as an 89ish.  and ill tell you its a hell of a lot more complicated than other obd1 cares ive had in the past. nothing like a gtr but my 96 type r and 98 mk4 weren't half as complicated as a GTR. its my third GTR still learning lots. I'm Never to proud to keep learning from knowledgeable members like yourself. thanks again.
I meant compared to newer cars, with surface mounted diodes on printed circuit boards; a body control module controlling your interior lights, etc.
Not sure why you're so aggressive, and have to boast about having multiple GT-Rs. Like I said, they're late 1980's cars, just crack (not literally) them open and have a look.
I'd also throw in a headlight relay harness/wiring while you're at it, the standard circuit is shit.
ahhh sorry not an aggressive guy at all and definitely appreciate your help over this month.  I only own 1 gtr ive just had a few in the past. I have nothing to brag about I live in a tiny house and barely have enough to even get by but we do what we can as we love cars in the family.  didn't mean to come across like that at all m8. and I have done the headlight relay and added day time running lights.  niZmO_Man has been a great help much appreciated.
ya I live in a small town in Canada with no mechanical support for skylines at all so this site has been huge for me very thankful. ive been on the site for 10 years but never felt worthy to ad up an account as the boys on here are leaps ahead of my ability. cheers tho boys all is well. hammer down let that rb roar!
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
