So after what the mechanic did it made a world of difference and worked much better. But still sorta got the same issue which is that it stalls when going uphill. also the car idles bad the tachometer moves very slightly up and down here are videos from after what i did to try fix it and seems to be a bit better. The idle also sounds better with the aircon on. Here is what I've done so far to try fix it:
* New spark plugs from 2 months ago
* Changed oil 2 times (first one for testing and it went black quite fast but now got brand new Penrite 10w-50 I think it is + filter)
* Cleaned IACV Valve was quite dirty but don't know how much it is (gasket is broken but used some gasket filler no leaks, might replace gasket later)
* Cleaned throttle body was filthy as well but didn't originally fix problem
*  New radiator coolant
* Cleaned pcv valve was dirty to but did rattle before cleaning and don't think it made much difference
* Unplugged air flow sensor while car is on and it turned off so that indicates to me the sensor is good
Don't know what it could be, don't think it's the coil packs, haven't checked oxygen sensor. What do you guys reckon it is? Maybe pressure plate? Don't think it's the head gasket. I wanna try work on some stuff until he arrives see if I can fix the problem in the mean time.
This first one is with air con on the idle sounds better and second one is with aircon off and idle sounds worse
You need to pressurise the intake to find a boost leak.
You haven't posted about what mods your car has, so we assume it's standard.
BOV:http://jp-carparts.com/nissan/part_detail.php?maker=nissan&type=89&cartype=7&fig=144&part=1448369F02&page=2&img=144B 002
14 minutes ago, silviaz said:
I dont think this car has a blow off valve?
Don't make the mistake of thinking that all BOVs are externally venting wank noise makers. The Nissan turbos had recirculating BOVs, although it is technically more correct to call them a compressor bypass valve.
Ah ok looks like i need to take apart the turbo according to that diagram?
Not sure why you would say that. To pressure test the inlet tract you should probably google up a guide - it has been discussed here bazzillions of times. You basically just need to access the inlet of the turbo (and some bits and pieces).
The diagram you were shown, shows all the pipe and shit that could participate in a vacuum/boost leak. I've circled the BOV for you
cheers
  • Thanks 1
cheers
My bad it looked like i needed to looking at the diagram lol
cheers
Fixed it. Timing was out by one tooth
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
