For Sale, OSgenkin twin plate clutch (push type suit rb25 series one and rb26 32-33 or rb30 etc , rebuilt by Direct clutches in Brisbane (with receipt) , done 3000ks in a show car so other than a few dyno runs and 2nd-3rd gear pulls on the street it's done stuff all work, never seen the track.
Was working perfectly when removed and had a good peddle feel and never slipped at 400rwkw
Only selling due to going manualised auto
Will come with the correct thrust bearing to take out all the guess work for setup
1250ono
Pics available via request
https://www.sau.com.au/forums/topic/479558-rebuilt-twin-plate-clutch/
1 hour ago, Chrisko33 said:
Would have been perfect but it’s a push Type r33 Gtr come pull
Buy a converter, most multi plate clutches for r33 gtr are push type and you use a converter to make it work
  • Like 1
  • 3 weeks later...
It's actually cheaper to properly convert to all the genuine Nissan push gear than the giken converter. I've done that on the 33 - push slave, line, box front cover, release fork, bearing and bearing carrier.
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
