For Sale, OSgenkin twin plate clutch (push type suit rb25 series one and rb26 32-33 or rb30 etc , rebuilt by Direct clutches in Brisbane (with receipt) , done 3000ks in a show car so other than a few dyno runs and 2nd-3rd gear pulls on the street it's done stuff all work, never seen the track.
Was working perfectly when removed and had a good peddle feel and never slipped at 400rwkw
Only selling due to going manualised auto
Will come with the correct thrust bearing to take out all the guess work for setup
1250ono
Pics available via request
https://www.sau.com.au/forums/topic/479558-rebuilt-twin-plate-clutch/
1 hour ago, Chrisko33 said:
Would have been perfect but it’s a push Type r33 Gtr come pull
Buy a converter, most multi plate clutches for r33 gtr are push type and you use a converter to make it work
  • Like 1
  • 3 weeks later...
It's actually cheaper to properly convert to all the genuine Nissan push gear than the giken converter. I've done that on the 33 - push slave, line, box front cover, release fork, bearing and bearing carrier.
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
