Hey, I have a 94 r33 gtst manual skyline. My brother has just bought a VN ss. ive raced him and kicked his ass, but only when we were rolling at 20kmph. his is an auto its got the usuall mods like exhaust and extractors. So how do i take off so that i kick his ass, i know that if i get a good start, all he will see is my nice big round tail lights, but if i stuff up than ill have to chase him down, which i know isnt a problem i just wanna smoke him at the lights, cos hes a commonhore lover and skyline hater. Can anyone help? do i just drop the clutch at say 2200 rpm, or is there some other way. Please help?
https://www.sau.com.au/forums/topic/47956-how-to-take-off/
Practice, and some more practice. Launching a manual is more involved than an auto and probably less consistant until you have it down pat.
I would be dropping the clutch at more than 2200. Depends on clutch, tyres, surface etc.
Get down to a track and line him up and you'll see who passes the line first.
Adam
https://www.sau.com.au/forums/topic/47956-how-to-take-off/#findComment-966739
don't both racing commonhore's they are worth the petrol and wear on the car, having said that if you car dead keen to smoke him dropping it from about 4,500rpm should get it right in the rev range off the line.
I'm not to sure if you'd be able to beat him off the line entirely the VN's are 3.8L V6's and have a fair bit down low espescially considering it's auto it'll take off pretty fast.
https://www.sau.com.au/forums/topic/47956-how-to-take-off/#findComment-966755
IMO dropping the clutch is the worst thing you can do for a good launch.
I used to slip and ride my clutch off the line from about 3200rpm-ish... it got me moving smoothly and at the same time was building boost. HOWEVER its a real bitch on your clutch and will wear it out if you are constantly doing that.
Dropping the clutch in a RWD car will either bog down or wheel spin
my experience and opinion only.
https://www.sau.com.au/forums/topic/47956-how-to-take-off/#findComment-966768
Its a VN ss so its a V8, And ive done a little bit of practise and found that if i drop the clutch any higher than say 3,000rpm it just frys the tyres big time, its only got a cat back exhaust a pod filter and a 2800ft pound pressure plate and standard clutch. So i think 4500rpm will just be way too much wheel spin, somtimes even when i drop it at like 2800 rpm it has heaps of wheel spin. so what do i try, i really wanna smoke his VN V8 off the line, and show him that skylines are shit. any help would be much appreciated
https://www.sau.com.au/forums/topic/47956-how-to-take-off/#findComment-966778
yea seems a little high i havent really been pracing but my gts-t is bone stock and i found slipping it alittle from around the 3k mark still lit the back tires up for a second or two then traction was back and i was on my way :cheers: (ps take it to the track much safer ;))
https://www.sau.com.au/forums/topic/47956-how-to-take-off/#findComment-966798
I personally reckon it's not worth racing your beautiful piece of art and craftsmanship, they are good cars, if you take car of them it will be much better off in the long run. The skyline engines like to rev so rev them don't drop the clutch on em.
Personally I reckon automatics will be able to bet a manuals off the line.
I used to own an R31 Skyline, it was auto, i'd put my foot on the break and rev it to 3,000rpm then let go and it would take everything off including new monaros and skylines the line but never could beat all wheel drive cars, just had to much traction off the line.
https://www.sau.com.au/forums/topic/47956-how-to-take-off/#findComment-966823
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
