Can someone tell me what this sounds like?
situation is under throttle even if its full or half throttle
car appears to not go anywhere just as if the turbo is not working.
i can hear the car spool up though and the guage reads the right pressure.
it makes no differerance if i run 8 pound up to 13 pound.
only engine mods are
hks pod
blitz boost controller
stock turbo
stock cooler
where should i start looking?
could it be the spark plugs or coil packs?
or would it just be sometype of leak?
Thanks Guys
https://www.sau.com.au/forums/topic/47958-problem/
Loose or broken intercooler hose
yep yep yep yep.............I totally concur Inasnt!!!!!!!!
Mine gave the same effect regardless of boost pressure I manually dialled in.
It was found to be just a silly loose big hose clamp just prior to the plenumn.
Tightened her up and back to normal.
I feel your pain, but ur making boost (pre boost-gauge anyway...and that's all that matters!!!), it's just not being sent to the right location cause it's VENTING from somewhere to atmo!!!
You'll be fine! Just check everything (hoses/clamps) and don't take anything for granted.
.........unless ofcourse your turbo really is stuffed!!!
SSMark
https://www.sau.com.au/forums/topic/47958-problem/#findComment-967379
SSMark
hmm but if the boost gauge is showing + boost then theres boost going in as the gauge is getting the reading i assume from the intake plenum so theres compressed air going in the plenum.
https://www.sau.com.au/forums/topic/47958-problem/#findComment-967730
Just reading your post again. Your prob sounds similar to mine.(see post in forced induction) making boost, reving out, no audible pinging etc. I replaced spark plugs bout a week ago, tested coil packs, fine. Ill let you know if i come up with something. Went to overtake a ute pulling a trailer today at 110, only just made it past :Oops: lol
https://www.sau.com.au/forums/topic/47958-problem/#findComment-967962
nope......good point!!
But wouldn't the reading of the gauge depend on where it is tapped into?
ie: ......tapped straight into the plenumn, your point is true (plus you've blown my leaky hose bracket out of the water 'cause there are none left at this point)
But if ur gauge is tapped well prior to the plenumn (like mine is at present), chances are there could be a leak after the gauge tap.
BUT...aha...if you had 2 gauges (in the interim) you could 'narrow down' the vicinity of that leak!!(??????)
I'd bet that this skliner has got a gauge tapped well prior to the plenumn.(?) and therefore his gauge shows boost (it is there!!), but it's not going where it should.
It just doesn't sound like timing or plugs to me. (i'm sure he'd be 'complaining' differently if it was??)
wotdurekonmate? :)
SSMark
https://www.sau.com.au/forums/topic/47958-problem/#findComment-969033
ill have another good look tonight, and i will tell you were my guages are tapped into, i have one for my electronic boost controller that gives me a boost reading and another for the old school type gauge that also gives a reading, they always match also even since i have had the problem. but yeah i will let you guys know where bouts they are tapped into tomorow morn.
ill check all my clamps also but they seem all sweet, havent looked at the cooler pipes, but i only have a stock cooler.
cyas
https://www.sau.com.au/forums/topic/47958-problem/#findComment-969053
  • 1 month later...
Have you fixed the problem ?
If you havn't I'd say its your timing, your crank angle sensor sounds like its been too far advanced thats why its making boost, reving and going no were. Try turning it back a little bit and see if it improves or get a timing light and set it back to standard.
:mad:
Jun
https://www.sau.com.au/forums/topic/47958-problem/#findComment-1028072
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
