i am curious about my 6boost manifold i thought they were ceramic coated. turns out its not. you guys think its worth taking it back off and have it ceramic coated.......
funny this was mentioned my mate just melted his engine harness from to much heat by the wastegate. i ran my wiring in my fender so should be good to go that way.
Be better off making a heat shield IMO. Don’t worry about the expensive paint job, it does sweet FA.
  • Like 1
ok thanks mate save me from pulling it apart. we got the catch can and a few other things finished tonight and got fluid in the car. download some maps tomoro and start it. cheers
im starting to kick myself for getting a platinum pro and not an elite 2500 at this point....oh well i guess ill use what i got for now. i highly recommend going straight an elite, i dont even know why people bother with the platinum series.
  • Like 1
bought it before i even upgraded my twins back in the day. so its just what i have and will definitely work still. if i was an endless money pit i would upgrade again but at this point just gotta get it runnning.
was still easy to set up the wb1, 4bar map sensor, haltec iat, flex fuel, couple other sensors,  all through the platinum. it is going to work just fine for now. i had to get a upgrade to run 1 to 4 can ports to run the haltech screen and the wb1 through the same system. other than that for a street setup i think im good to go.
Finished getting rid of all the hicas crap and welded a 8an on remaining line from rack. Will run it to the reservoir i made(still need a bracket) and will finally be able to start this thing.  Got the wide band figured out to the haltech it’s almost go time!
I have hit a snag I feel like I don’t have this setup right. The directions don’t even have the pigtail out the back like on my wb1 can sensor they sent so the directions make no sense. Need help finishing this up, I have ordered the can box extension if that’s what I need to get this setup, I ordered it so I can run the haltech screen as well as to my understanding I needed it to run more than one can device with the platinum series versus the elite
Finally got all this figured out for the haltech to power all my shinanigans. Learning way more and finding out the last 10 percent of putting the car together is more like the last 30 percent haha. Getting her done tho slowly but surely. Family life comes first cheers mates
  • Like 1
Made some progress  in the old boot tonight. That’s it till tomorow and yet another day of fabbing,slaying trees,and maybe start this machine.
  • Like 1
7 hours ago, r33cruiser said:
How did you get the double garage all to yourself?!😲
Wifeswap?
ahh chap funny thing the property to my east came for sale for next to nothing, so i scooped it and building another garage to my east! worked out great even has a little house on the property still im renting out. the gtr gets the silver spoon yet again while the other whips sit outside ha. cheers good mate.
FYI when making brackets like these for your battery get some fuel tank straps and line them(semi shop will have them made from rubber) because you will accidently ground your positive and negative together(hence why my posts are taped because i shorted my brand new battery for half second and learnt the hard way.) cheers
Another night of hammering down on some fab work. I hired a new welder for the shop he’s only 25 and can throw it down. Anything needed he’s done quick with a great attitude I couldn’t be happier.
  • Like 1
When your welder runs out of argon on a Saturday in the middle of tree cuttin job! Shift that argon ten speed right back to the shop then full send back to the job site! Catch cans looking deadly this kid can fricken weld.
Well today was the day Just gotta tune her tunes up now. Thanks to Ben (bk) helped me a lot through this, and a bunch of my friends. Was great to see everyone come together to get this car complete. I have learnt many lessons through this experience. Cheers mates. More to come.
  • Like 2
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
