Parts List
OEM Nissan Parts:
R33 Gtr Rb26dett Engine
R33 Gtr 5 Speed Transmission
R34 Gtr Front Subframe
R34 Gtr Front Lower Control Arms
R34 Gtr Front Upper Control Arms
R34 Gtr Front Knuckles
R34 Gtr Steering Rack and Pinion
R34 Gtr Front Sway Bar
R34 Gtr Front Coilovers (Ohlins)
R34 Gtr Front Axles
R34 Gtr Front Brakes
R34 Gtr Front Brake Lines
R33 Gtr Front Prop Shaft
R33 Gtr Main Prop Shaft
R34 Gtr Rear Subframe
R34 Gtr Rear Diff
R34 Gtr Rear Axles
R34 Gtr Rear Control Arms
R34 Gtr Rear Hubs
R34 Gtr Rear Brakes
R34 Gtr Rear Brake Lines
R34 Gtr Rear Sway Bar
R33 Gtr Attesa Pump
R33 Gtr Attesa Fluid Reservoir
R33 Gtr Transmission Crossmember
Aftermarket Parts
Engine:
HKS 2.8L Rotating Kit
HKS Valve Springs
Tomei Pro Cams
HKS Timing Belt
HKS Cam Gears
N1 Oil Pump
N1 Water Pump
HKS Gaskets
G-Force Silicone Coolant Hoses
Reworked R34 N1 Turbos
Tomei Turbo Dump Pipes
Apexi Downpipe
Nismo Flywheel
Nismo Clutch
Fuel System:
AEM In-tank Fuel Pump
Aeromotive Fuel Pressure Regulator
8 AN Fuel Lines
Aluminum Fuel Rail
GM Flex Fuel Sensor
Chassis:
Nismo Engine Mounts
Nismo Transmission Mount
HKS Exhaust
Chase Bays AN Power Steering Hose
R34 Gtr Aluminum Radiator
Electronics:
Adaptronic eMod004 ECU
Full Race ETS-Pro Diff Controller
Wiring Specialties RB26 Universal Pro Engine Harness
Greddy Boost Control Solenoid
Depo Wideband 02 Gauge
R33 Gtr Drop Resister
R33 Gtr Ignighter
Misc:
HKS M35 Spark Plugs
HKS Oil Filter
Royal Purple Engine Oil
Royal Purple Gear Oil
Royal Purple ATF
3D Printed MAF Delete Pipes
Sprinkle of Magic
  • 4 months later...
  • 5 months later...
I'm curious to know whether the OP had to modify the chassis legs to clear the front axles. It would be a show stopper in NZ. See the raised section on the BNR34 chassis:
Edited by NZ-GTT
 I found that the GTR subframe sits approximately 2 inches lower in the car than the GTT sub frame.   So what I did was box the end of the sub frame mounts adding that additional 2 inches and contouring it to the frame of the GTT.   Then I drilled 1 inch holes through the existing frame rails vertically and sleeved them with a .060 wall tube.   I attached the sub frame to the existing frame rails using 1/2 inch grade 8 hardware.   Keep in mind that you also need to modify the driver side floor pan as well as the driver side frame rail to except the GTR transmission mount.
  • Like 4
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
