Hey guys I’ve got a ADM S15 SR20DET all I’ve done is added a pod filter and completely removed the BOV and blocked it
Planning to add these mods
Free flow air filter
Free flow exhaust
Upgraded fuel pump
Boost controller
Front mount intercooler
Colder spark plugs
Custom ecu remap
Z32 AFM?
Just wondering do I have to upgrade injector,fuel rail and turbo? Or can my stock turbo, injectors and fuel rail handle it Aiming to get 200rwkw I don’t mind if it’s a bit less than that and not needing to upgrade the turbo, injectors and fuel rail
and can i still run with without a BOV
sorry for the noob questions any help will be appreciated thank you
https://www.sau.com.au/forums/topic/479611-need-help-with-mods-for-s15-newbie/
I don't know what the limit of the S15 turbo is, but it will likely be in the 200rwkW region, so max it out and be happy. I think the max boost territory is 18 psi. You should really google a bit to find out.
You will not need to upgrade the fuel rail, ever.
I have no idea what the limits of the injectors are. What are they? 440cc? 480cc? Either of those should easily be enough to support 200 rwkW, but you will almost certainly need that fuel pump upgrade.
You can't just "custom ecu remap" your ECU. Well, you kind of can, but it's a bit 1990s. Nobody f**ks about with that stuff much any more. You should get a Nistune daughterboard installed in the ECU. That is real-time tuneable.
Don't f**k about with colder spark plugs unless the engine shows that they are needed.
Air filter is a waste of time.
I have no idea of the limit of the SR20 AFM. It is maybe possibly less than 200rwkW. If so, then you would want to upgrade to a bigger one. But no-one in their right mind would put a Z32 AFM onto a car these days, since the availability of the R35 and similar card type AFMs. Nistune can handle them.
I would never run without a proper recirculating BOV, especially on an AFM car.
Depending on the dyno, the stock turbo, injectors, afm will make it to 180-200rwkw at around 16-18psi boost. The fuel pump definitely needs to be upgraded. A Walbro 255 is perfect for your goals, just make sure it's genuine (there's lots of fakes going around). You will also need a good bell mouth dump pipe (turbo elbow) and 3 inch exhaust. Off the shelf will be fine for your goals. A decent sized intercooler is also needed. Nistune is my recommendation for the ecu.
With e85 you can get to around 220rwkw on the stock turbo but will need even bigger pump, injectors and possibly afm.
200rwkw in an s15 is quite a nice happy medium.
The above info is right. A pod filter is an upgraded air filter for the engine, so you kind of already have that.
The stock turbo is metal wheeled in a S15 so it can handle higher boost pressure and as above, 190-220kw is doable depending on how hard it is pushed and what fuel you use (E85 vs 98 etc).
Get a good solid exhaust, good solid intercooler, I too don't know if injectors and pump are up to the task of maxing out the standard turbo, but a modest goal like yours should result in actual happiness and a fun vehicle that isn't constantly broken.
Try to resist the urge to go mental and impress people on the internet with a car that sounds great on paper but can't be used for anything cause constantly broken, which is a very real thing that people with big power cars kinda don't disclose very freely.
  • Like 1
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
    • I presume it would take more than just slapping a big modern catalyst on the exhaust? It's interesting though, looking at the old sales brochures and listings it does not mention anything about emissions. No one cared.
    • Yeh nice, looks like their part of keep it reet? Will have to swing past. I'd much prefer someone actually look at my car and custom make a part, then get a generic part online and hope it works.
