Well the good news is a bad ground might stop something working, but it won't break it. Even if a short is caused you should only lose a fuse, not the control unit.
There is a ground from the body to the rear subframe that is often removed or broken, particularly if the subframe has been out. That ground missing is the most common cause of the error you saw, but not it this case it seems
Duncan thanks for your input throughout, in fact I was up late trouble shooting and wow I’m glad I did that I forsure would have wrecked another ecu. I attached the workshop manual page with the procedure I followed for code 24. I got to testing the coninutuity and the numbers were super dodgy sometime getting low reading but jumping all over. Sure enough rear ground was completely loose at the frame but still making somewhat of a connection. Would have eventually ate my ets cu. the rust was misleading but helped me fix my washer fluid issue. Hope this thread helps lots of people with code 24. Follow the manual it never lies.
Edited by MoMnDadGTR
  • Like 1
In fact I was so happy I found the issue, I took my car for a good rip this morning in the snow lol and did some slides at the shop, thanks again boys.
1 hour ago, PanoramaLife said:
Duncan,thanks for sharing
Yes smart guy has helped me lots much appreciated.  the manual is good for trouble shooting. Having good grounds, good ets connections, clean abs sensors, bleed atessa, replaced ets control unit(used) check for codes, address codes.  topped it off with a du-lock v2/quaife diff on circuit setting and cars a totally different machine with no issues anymore. grounds were a big one as well, cleaning contact points with new ground cables on rear diff to subframe, battery/frame/engine, added a engine to frame ground where a/c used to bolt to engine, ground from firewall to engine.
forgot to add and also covered a zillion times but make sure your tps set to .4 max .5.  This also threw a 4wd code on my ets unit when I replaced it. I set to .4 and she was good to go. I did this with car not running.
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
