Howz it going guys,
I just brought my self an R33 and i live in Melbourne. My skyline has a BOV on it and i want to keep it on there, besides it sounding good it's also good for the turbo as we all know. Does anyone know if it's possible to keep the blow off valve on the car and keep it legal.
Thanx Matt.
https://www.sau.com.au/forums/topic/47963-blow-off-valves/
Howz it going guys,
Thanx Matt.
Only if its not venting to atmosphere and plumbed back in like the standard unit as far as I know. Then you loose the sound, so might as well have the stock unit and no problems.
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-966899
Thanx guys so there is no way not even if i get an engineers certificate to say that the car requires one or that it is fitted as to his specification does anyone know if thats possible. i wanna try cover all areas to get around this one and im sure others have done this process and know the facts.
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967000
just quickly about BOV's, i have seen some BOV welded on the intake pipe. is that still illegal?
If its on the intake pipe.. before it hits the turbo, its not really "bad" air so to speak... at that point i would have though.. so it should technically be legal..
correct me if i am wrong guys.. still a noob :cheers:
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967009
You can't get a BOV engineered (unless it's a plumb back)
You can't get a certificate to say the car "needs one"... because it doesn't.
uh.... are you sure you aren't talking about air flow meters?
I don't know why anyone would put a BOV on the intake, it wouldn't do anything.
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967033
Is there any mechanical benefit on welding the BOV onto the intake as it's not getting rid of any excess air from the turbo or is it? And will it still cause a big and hard working turbo to stall on deceleration???
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967358
I have a HKS SSQV and the standard R34 BOV. I leave the HKS BOV off most of the time as it attracts too much attention and is just asking for a defect notice.
If the car comes factory fitted with a BOV then it is LEGAL. My car went through ADR37 compliance like every other import vehicle, and all factory fitted items are noted as compliant. The fact that the factory R34 BOV makes a wooshh sound makes no difference, it is a factory fitted item and my compliance plate says it passes as compliant so the cops or EPA cant do sh!t about it :)
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967458
Aftermarket BOV with plumb back will still make noise, well mine does any way (GReddy). From my experiance if you run high boost like mine does (1.5 bar), then an aftermarket one is needed (my stock one starts leaking for some reason).
My 2 cents worth.
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967597
the stock bov with a pod filter is pretty loud, just like a normal blow off valve, i dont see the need for an aftermarket bov unless you run a crapload of manifold pressure from heaps of boost aka 20psi ++
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967774
does the factory BOV make a venting to atmo sound??? I wasn't aware of that. Still haven't got my R34 so i don't know :rofl: never driven one either :D
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-968123
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
