I have a 1996 skyline gtst and it’s hesitating at higher rpm so I decided to change my spark plugs to possibly fix it. The plugs I put in are NGK bcpr7es. After I started driving it seemed fine at first then it started to shake and there was a loss of power. Also when I was coming to a light on my way home it stalled when I was decelerating. Does anyone have any ideas what could be wrong?
https://www.sau.com.au/forums/topic/479636-rb25-stallingshaking/
1 hour ago, Blakecarter said:
The coil packs looked fine but that could be it and they are the standard ones
They might look fine, but generally if they're the OEM ones since 1996 then there's a very high chance they're anything but fine.
And if you do decide to replace them, steer clear from red, yellow, pink, green, etc. ones. They need to be either black (OEM, 370Z, R35) or blue (genuine Splitfire).
* eats cold pizza for dinner *
Try to search for this: coil packs, coilpacks, AFM, air flow meter, IACV, idle air control valve
After you have done extensive researching, and your issue isn't fix, update this thread. If in doubt, replace engine with LS V8
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
