R31Nismoid:
ok so you are going on a chassis dyno to run the engine in.
are they going to do a full power run/tune? I understand you have a GT30 so are you going to take a freshyly rebuilt engine on a chassis dyno, do a few ramp ups to bed the rings in and then go all out 20psi 7500rpm power run and tune?
R31Nismoid:
I shall ask the question tomorrow of how it is all going to work.
But i beleive thats whats going to happen, once i drive out the roller door.
But yeah, ill find out in detail tomorrow
that'd be tops (Y)
then i can get more info and pass it onto my dyno guys.
Reckon you could find out the procedure for run in to etc and what it involves? They may keep it secret tho :S
I reckon i can indeed. I was getting told the plan of attack two weeks ago as i asked about running in and stuff and i was met with an odd look (i now know why)
I was told that he was sick of running in race motors as it took so damn long, so he didnt bother anymore.
After a 6 month hiding on the track, he would pull em apart and they'd look no different to a motor than spend hours & hours being "run-in"
So no long winded running in.
anyway, more to follow tomoz
Mine will be thrown on a car trailer and towed down to Shauns where he will run it in there.
I am curious as to how spot on the powerfc's base map is AFR' wise.
I will find out tomorrow I guess. :D Won't I Darren ;)
Son of a bi....:) Can i borrow your guineapig suit then? :)
haha i was met with that exact same look when i asked the same question...
mine should be due early next week and from what iv been told, by the time the car has been tuned up itll be ready to go without any "running in"
he (Ian at Amberly) said running in is an old term, when it comes to purpose built engines, all clearence and measure are done pretty much exact
who knows...but id belive what the builder says, especially if theres repuation to back his claims on engine building, not something someone wrote in a magazine
rings still need to be bed in properly. If they say something along the lines of what was siad above, id assume they are taking your car for a few hundred kms of run in driving....clearances done pretty much exact :bahaha: it would want to be, but rings still need to bed :)
Speaking to somebody yesterday about running in engines and was told similar to what R31nismoid and whistla said.
"Purpose built performance engines actually dont need as much running in as a mass produced ( falcon,commo) engine. Mass produced engines have less tension in the rings and therefore need a longer run in period to bed them properley. Whereas a performance engine will generally have a higher ring tension and bed a lot easier and faster. Car manufacturers have low tension rings as it creates less friction = less wear = better fuel economy."
But nonetheless rings still need to bed, no matter what engine they are in.
do u guys know how long a motor from Holden is "run in" fpr instance??
I do... and if you find out you'd see most others' point.
The fire em up (on mobil 1 sythetic) give a squirt check everything is in order (pressures etc etc) and whack em into the cars. They dont spend hours on an engine dyno or anything bedding in rigns blah blah. Not as if thier motors dont last many 100,000's of km's
Rings dont take hundreds of KM's to be bedded in.
I took put my stardard computer in my RB30DET to start it up. I drove it to the workshop and put it on the dyno. They told me it was running very lean, so i put my wolf in and they tuned it for right mixtures up to a 4000rpm rev limit while running it in. It is geting fully tuned after ive done 1000km, since ive just got to bed the rings in. Im glad i got the mixtures checked because i could have done damage. Will find out how much power its got by wednesday.
Yes Ash, I know what the manufacturers do. I also read somewhere that sometimes the engines are taken to redline to ensure everything is ok.
But you said : "do u guys know how long a motor from Holden is "run in" for instance??"
That is a misleading comment in the sense that a new car owner is not told there engine is ready for "normal" use. You are told you have to run it in and it is in the owners manual explaining the manufacturers recommendations on how they want you to do it.
A perfect example I would love to see is the GEN 3 engine. One driven hard from the outset and one ran in on the dyno as per Holdens recomendations. And then see which one has the better oil consumption.
I dont agree that a performance engine needs a long drawn out run in process but I also dont agree that it can be taken to the limit from the get go.
Whistla wrote: by the time the car has been tuned up itll be ready to go without any "running in"
Can you ask your builder approx. how many ks will it take for it to be "tuned up"
mine (same as mr whislta) will prob be done on dyno and thats it :)
Hi Ash, I think you will find that he will run her up on the dyno for initial break in and tune then advise you to come back after around 500 km's. In my experience he also knocked out a few degrees of total advance during the break in period.
yeah i think i'll take mine to get the mixtures checked out, this dyno time will also be loading it up a little helping bed the rings in... once the mixtures are ok, go driving for 500-1000km's then come back and say 'boost this mofo right up' :)
yeah i think i'll take mine to get the mixtures checked out, this dyno time will also be loading it up a little helping bed the rings in... once the mixtures are ok, go driving for 500-1000km's then come back and say 'boost this mofo right up' :P
exactly what i was told...and will be saying :D....500-1000kms is the critical bit, then let it fly :rofl:
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
