Yep !
How good is the car ( before it was smashed that is ) ?
If its a clean unit get multiple quotes on repairing it.
Post up some pics of the damage so we can get an idea of whats involved.
I'm assuming it wasn't insured or you don't want to go through insurance ?
Then try and get a basic parts list together and source the parts yourself second hand and then get a quote for repair.
That's >$5k right there. Probably a lot more than that because the inner guard is smoked and the rad support and the chassis rail probably generously bent. Whether those parts are straightened (if it's doable) or replaced, will both cost a few bucks. Then you need all those external panels and lights and radiator and other plastics. The $$ add up quick.
You won't fix it yourself, because you'll need more facilities than anyone reasonably has at home, or even in a friend's workshop, unless that friend is a crashie.
Back in the day when I had free time, I would disassemble the front end, bin any broken parts, tow the car to a panel shop and get them to sort out the front end structure.
Then bring it back home for reassembly with second hand parts and possibly paint, or cashie job by a painter
Would be a decent saving but you would need a panel shop willing to do that kind of work, most will ask you to politely gfto
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
