Effects of high-duration camshafts and reliability of leak-down tests in gauging engine health
I've heard and read various things regarding what is and isn't normal ranges for leak-down tests. Some sources say anything over 10% requires attention, others say over 30% is catastrophic and in need of rebuild, yet the tools used to perform such tests often show that 10-40% leak-down is considered 'low'. On the flipside, I have also heard that high duration camshafts and other variables can cause healthy engines to give readings of 30%+. In this particular instance also, a compression test showed nothing of concern and all cylinders were within 8psi of each other.
1. What else can cause leak-down test results to be 'high' in a healthy engine?
2. Can truly healthy engines produce high leak-down test results?
3. If high-duration camshafts can be the cause of high leak-down results, why do they cause this?
4. Are leak-down tests reliable measures of engine health for moderately worked engines? i.e. are the definitions of high and low results only relevant for standard cars?
Any definitive insight (rather than speculation) would be much appreciated.
Edited by Iron Mike
High duration camshaft CANNOT cause high leakdown results. Leakdown tests are only done when both valves are closed. Ergo, cam duration is not an issue. cams with big duration will cause low compression test results, for the obvious reasons that they let the compression back out through the intake valve while the piston is closing.
Truly healthy engines can have higher than expected leakdown because forged pistons with higher clearances and wider ring gaps will simply leak more.
A leak down test doesn't distinguish between modified and stock engines. There is no definitive answer its all relative. In my opinion anything more than 10% needs to be investigated which is not the same as saying you should panic and order a complete rebuild.
I have heard from a reputable GTR workshop that it can though I did not get the chance to ask them why ?
Unless you're dealing with a motor built for big boost and big horse power with very big ring gaps, then yes you'll get an undesirable leak down result.
Pretty much what @GTSBoy said but in simpler terms.
Big ring gaps would cause low compression on a comp test but this particular engine is reading 162-170 psi across all cylinders.
Nope. Will cause lower psi than it might without the large gaps, but compression is a very fast process and the leak rate out through the gaps is "slow" compared to the compression pulses. Whereas, leakdown tests are steady state.
The sad fact is.....if the engine is truly leaking more than it should and you are "sure" that the bottom end is healthy, then the seats are bad.
There's only two good explanations. Either they were thinking of compression tests when they said that or they're not actually as reputable as you say they are.
  • Like 2
Ok cheers. Also with the various ranges for acceptable leakage often being quoted at <10%, <20% , <30%, why then do all the leak down guages show it being "low" and in the 'green' under 40%? See pic attached for reference
Because there is no standard. Much like engine building each builder will have their own preference, with most agreeing within a certain range.
it’s not clear cut. , and all the tests in the world on an assembled engine won’t tell you if it is about to Grenade itself due to a small mistake/issue.
  • Like 1
Because Snap On don't want you to blame their tools for telling you your engine is farked.  To say 40 - 60% leakage is "moderate"  is plain ridiculous. Have you actually carried out a leakdown test on your car? What were the numbers? If you have you will know that the test is carried out with the piston at TDC and both valves closed so its hard to see why you think the lift or duration of the cam should make any difference.
Wouldn't it be the other way around? Ie. Wouldn't Snap on want that leakage bound to be conservative to avoid the scenario where an engine is actually f****d and the guage implies it's in good condition?
Regardless, it's not just Snap on. All the guages I've seen have the same bound for low leakage being 40%.
Any more than 15-20% is cause for concern. If the engine is still being broken in the rings might not seal very well but afterwards it should be 10% or less when the engine is warmed up.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
