Hi all,
Really hoping someone might have an idea on this issue. I've tried Pulsar specific forums but no luck.
(backstory)
Car wouldn't start, got NRMA (roadside assistance) out to jump start, and he tested the battery while car was running, to check alternator (14.## volts), he said alternator was OK, so we drove it home. Next morning, went to get a new battery, car started OK, but at autoparts store, they tested battery and came back 'bad'. Bought a new battery, installed it....
Basically car is idling/stalling, which I 'think' might have to do with replacing the battery. Starting the car, it would start, then die. Only way to get it to start is to apply a little accelerator. After a few seconds, remove acceleration and car would idle, poorly (probably around 500rpm +/-). If I accelerate (1-2k rpm), and release foot, rpm would drop right down <500rpm, almost stalling, then it would pop back up again.
I thought maybe fuel was dirty, but Mum said she fueled up a few days ago, but didn't notice any issues.
I checked air filter in case blocked, didn't seem to bad, a little dirty, but nothing suss.
Checked oil in case was low, and maybe causing friction in cylinder.. probably very unlikely, or pointless, but figured why not, while I had the hood up. (oil was 50% full, but needs changing)
I have heard that replacing a battery can turn the ECU dumb, causing it to have to relearn. I've come across a few procedures, but none seem to work;
http://afiaustralia.com.au/images/stories/N16_pulsar_idle_fault.pdf
https://ricksfreeautorepairadvice.com/nissan-idle-relearn-procedure/
https://www.youtube.com/watch?v=CR-AjHCslhs
https://forums.nicoclub.com/how-to-ecu-relearning-procedures-t445702.html
Following the steps in the 1st link, step #6 says to "disconnect Throttle position sensor (brown in colour) connector", but there is no brown connector, just a single green one. A service manual I found shows a diagram with a brown (throttle position sensor), and a Grey (closed throttle position switch), but our Pulsar just has a single green connector. When I disconnected / reconnnected that one, the accelerator went limp, couldn't rev the car. Had to turn car off for several seconds, then on again, now back to square one.
I tried an OBDII reader too, just one of those ebay jobs, with the Torque (lite) Android app, but I got an error in Torque,
still loaded into Torque, but pretty much nothing would connect (except acceleration, which maybe ran off protocol 3, which I think Torque said was OK). I tried OBDLink, but wouldn't work unless I had one of their readers. Also tried BlueDriver, but wouldn't detect my reader :/.
Note: i just found this entry on wikipedia regarding the QG18DE engine;
OBDII – On-board Diagnostic System (codes can be read/erased by a variety of readers, e.g. Actron blaZt). Nissan Pulsar N16 Models without EuroOBD in Australia do not have OBDII.
If the car doesn't have OBDii reader.. what does it have? It has the port under the dash that connects a reader, so it must take something ?
Vehicle is a 2003 Nissan Pulsar N16 Auto 1.8L QG18DE engine.
Thoughts ?
Thanks in advance.
Pretty sure its still running Nissan Consult protocol. As for the rest hard to say, used to have a similar issue with the old V6 Magnas, and was generally resolved by cleaning the throttle body
Thanks for the reply.
I had a look at the port under the dash, and it appears to be an OBD2 style connection. Looking at the Consult cables/adapters, its port connector appears to be a different style. Could it still be using a Consult protocol but with a 16pin OBD2 port? or is the car likely to be some sort of EOBD (euro?) connection ?
I'll try giving the throttle body a clean too, and maybe check for vacuum leaks while I'm at it. :)
Edited by LeWidget
I don't think it will help too much towards resolving the stalling, but yes, Japanese cars in general, and Nissans in particular, can have an OBD port physically, but not support the OBD protocol. Sometimes that is generically called J(apanese)-OBD but it is not even a country wide standard, each manufacturer and potentially model made decisions about how to implement it. OBD is only standardised in the US, and even then it only requires a specific set of functions, not all the information that might be available within the CAN
Have you tried disconnecting the battery for about an hour? It should give enough time for the ECU to "clear" itself.
Or perhaps the IACV is stuffed/clogged/whatever, and the ECU trimmed it to be fully open, but now that it's been reset it doesn't know to open it (I'm just guessing).
https://www.justanswer.com/nissan/63g7y-idling-stop-light-2000-nissan-sentra-gxe-will-loose-rpms-try-stall-un.html
Might have to head down to a workshop (e.g. Mycar, Midas, or even Lubemobile) that can scan your car.
Sedan or hatch?
I've just got mine going again (hatch) after fixing a broken valve. It was without a battery for several weeks, but fired up and ran fine when it was all back together.
In Skylines, poor idle is quite often related to the IACV valve being dirty, could be the same in the Pulsar.
On 1/31/2020 at 3:11 PM, blind_elk said:
Sedan or hatch?
Sorry, it's a Sedan
I ended up cleaning the throttle body, was quite filthy, however, I couldn't clean the IAV as it was riveted to the throttle body.
Started car, started good. RPM went to around 1k, then slowly came down to 800rpm. Good!. Let car sit few minutes, no problem. Turned car off, started again, but, now it go upto 1500rpm and sits there. Turned off / on, same thing, tried again, same thing, 1500rpm :/. I might have to try and drive around a little, hopefully it'll adjust itself again, or maybe disconnected battery to reset ECU, and go from there ?
Still haven't been able to find a service manual for this one other than going to supercheap :/. I found this video (U.S I think), talking about relearning. The throttle pictured in the video looks the same as the one in the car.
https://www.youtube.com/watch?v=W1bsUedze5M
Another thing, I found this hose, doesn't seem to be connected to anything, can't see where it might connect to either. Is it suppose to be disconnected? Maybe a breather hose of some sort ?
On 2/2/2020 at 4:46 PM, GTSBoy said:
Is the hose sucking air in when the car is running? If so....problem.
No suck. I've been told it's a breather hose.
As to the idle valve. Buy some Subaru upper engine cleaner or similar and spray it in through there.
Through the IACV or into the throttle body? Would spraying into the idle valve not cause issues? I read a few posts saying that TB cleaner, if it get's into the IACV, can damage it, though I tried to keep the IACV upright, so TB cleaner didn't run into it, could that be an issue ?
2 points here.
1. I did not say TB cleaner. I said Subaru upper engine cleaner. Not the same thing.
And 2. Regardless, carby/TB cleaner can't really harm the IACV.
And I meant for you to spray it into the IACV. You may need to have a few goes at getting some stuff in there. The best way would be to have the hose feeding it ready to pop off. Have engine running, pull hose and squirt some cleaner in, then put hose back on if it sounds like it wants to stall.
I know. I was just saying that in reference to spraying a chemical in the general area.
I had a look but don't see any hoses going directly to the IAC
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
