Hi guys
have done some serious work to my engine atm:
2.9L stoker kit
Neo ultimate head
Tomei 260 camshafts
Yellow jacket coil pack
otaku garage forward facing intake plenuim with a 90mm throttle body
and I’m not even on my L plates yet
thats why I’m doing all this work so when I get my p’s I can do an actual gtt turbo not a plus t setup
so if anyone has suggestions on what I’m doing and what I could do better please let me know
but back to my main question
can you convert the internals of a gt gearbox to a gtt
ive heard there the same just internally different but want to be sure
and should I be upgrading diff and drive shaft
thanks jack
No. The NA gearbox is physically much smaller. Like half the size.
You don't need to upgrade either the diff or driveshafts. Not for strength reasons anyway, as the diff is the same strength as the turbo item and the axles are nearly as good. But.....you will want an LSD centre on a turbo.
Note that I said driveshafts. You said driveshaft, and it is not clear whether you meant the tailshaft or the axles. Not that it matters, as both are strong enough.
It's also not clear what the stroker kit and other parts are fitted to. The NA engine? A turbo engine in the shed? If you've done it to the NA, complete waste of time. If you've done it to the turbo, well, the yellowjackets are not a good choice, but beyond that, everything else is OK, if largely a waste of money.
You will need brakes. And, are you sure that you will be allowed to drive a turbo on your P's?
Hi mate
yeah meant driveshafts sorry typo
and the n/a block is exactly the same as the turbo
And do you know what ignition coils I should run
im using the n/a block as it’s the same as a det but am putting det head on top
49 minutes ago, Jacks red r34 gtt said:
Hi guys
perfect example of why not to fit that style of plenum. lost 1000rpm of response and a bucket load of power. Green is factory plenum, the others are a short runner style plenum. Bin the yellow jacket coils and get a PRP r35 coil kit.
  • Like 1
Ok thanks
just wish the stock didn’t go over the valve covers
looks ugly and is really inconvenient when working on your engine
and do r35 coils stick out of cover?
13 minutes ago, Jacks red r34 gtt said:
Ok thanks
It's really not hard at all to remove the crossover pipe as required, which is not often.
Get split fires if you want it to all fit factory. You will have trouble with yellow jackets
  • Like 1
But look at the peak gain! And how much cleaner the engine bay looks.
  • Like 1
17 minutes ago, Jacks red r34 gtt said:
Btw could you link the coil kit
cant find it
http://letmegooglethat.com/?q=Prp+Rb+coil+kit
I don't like the look of most of those plenums and fitting the new plazmaman ones with engine in is a pain with the water hose/pipe underneath.
  • Like 1
No its NOT mate, no piston oilers for a start, and past experience of these blocks found that the turbo oil supply gallery has not been drilled either, or the turbo oil drain hole as well.
Edited by Rusty Nuts
Ok lol
lucky i haven’t installed anything yet
does anyone know if you can run the det neo engine without the turbo using parts of a device engine?
1 hour ago, Rusty Nuts said:
What the hell is that???????????
It's what happens when you exclusively access the internet on a phone, type "de" and have the stupid device (the phone) think you were talking about it and autocorrect to "device".
  • Haha 2
And just so everyone knows I’m not dumb it’s just I made a sau acct less than a day ago so am still learning
and robbo I thought you meant put r35 coils in a rb
that’s why I got confused
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
    • It will be salvageable. It really doesn't matter what is damaged. Opening up a 30+ year old motor for a rebuild immediately means a complete rebuild of the head anyway. Damaged valves just means an opportunity to put in some nice new ones. And in the modern day, why would you not throw at least a nice set of pistons at something. And if you're doing that, why not rods, and ARP fasteners, and so on.
