But does anyone know if you could put a de exhaust on a det neo and just put a pod on the end of the intake manifold
with a tune of course
No point doing an exhaust or pod filter on non turbo motors. Nothing to be gained except noise and a lighter wallet.
A bit of advice, google search all your questions and once you have exhausted that option then post in here.
like having a turbo is obvious to the bois in blue but unless they’ve studied the car they really won’t know what parts there looking at
so what I’m gunna do is get a det neo engine block, gtt drivetrain and brakes etc
and I’m gunna put my stroker kit and bore it out and put the performance head on but take of the turbo and intercooler and put on my gt exhaust system and intake on and hopefully I might be in the 170kw range
if not it doesn’t really mater because I can put a really good turbo system on and run a solid psi without worrying about my engine internals when I get my second p’s
what are your thoughts on this
and no I’m not gunna keep this car stock until I can drive a turbo and save up for a gtt if that’s what u where gunna say
thanks jack
Ah. 16 year olds and their endless supplies of enthusiasm, money and unwillingness to listen to those who have learnt from making those same mistakes.
My tip is put the Skyline in the shed and don't drive it and instead drive a $200 FWD shitbox for 2 years. Who's going to be paying for the insurance on this R34 of yours while you drive in illegally modified on your L's and P's?
Edited by GTSBoy
  • Like 3
Actually I’m not gunna insure it yet lol
ive been driving since I was 6 and haven’t crashed a single vehicle
not saying that I won’t crash but it’s a risk I’m gunna take, don’t roast me?
I’m working as an assistant at job sites doing work whenever I can and making 20 an hour which is pretty good
It's not a troll, but its a combination of inexperience really, which is fine, we all start there.
The first thing any cop will look for is a 20 year old import with a P plate on it.
The problem is a non turbo skyline, of any kind, in any form, is a completely shit performance vehicle.
Get an 86. Turbo that when you're legally allowed.
Source: Had NA+T, then 2.9 liter stroker kit (is yours brian crower too?) then built auto, then manual, then 5 different turbo choices, now have Legal V8.
Any idea you could possibly have, has been done. Some people like myself have done all of them!
You should listen to these people.
Alternatively, make mistakes and waste money.
These are solved problems by now.
  • Like 1
Yeah your all right
i had my whole build planned out but I never really thought about what has already been tried
I’ve done a lot of body work on this car and I got it for only $4000
I’ve cleaned and polished every part of this car but apart from a k and n pod filter everything other than body work is stock so I’m not having much thought about getting a gtt now
i would really like to keep this gt and just swap it later on for a det neo
should I just keep it stock and clean and put some good brakes and a solid shift kit on and det neo swap it when I get my full license
thanks
jack
And no im not rich but I’ve got a decent job for my age and yes I will get insurance
was a decision I made on the spot and didn’t think through
sorry for not listening to you guys
Thanks
jack
Ok thanks mate
saved me alota time and money
any suggestions on tires, suspension and brakes
am goin with the classic 19 te37 ultra track edition I recon
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
