On 9/3/2022 at 1:39 PM, Dose Pipe Sutututu said:
I'm still wondering if Xtreme GT-R is using a RB25 NEO head OR just adapted a NEO VCT to a RB26 head.
Custom VCT to RB26 head 👍
  • Like 1
  • 2 months later...
Nothing to specifically update here, but just putting k's on car and it's been flawless. The turbo elbow hose failure has been about the only recent issue with the car. I'm still running a silicone replacement until I can be bothered to pull the turbo compressor off and weld a proper cast alloy elbow on for a permanent fix.
Apart from that - no complaints. Still love the 2.8 / 6466 combo, the PAR box has so far proven to be very good and couldn't be happier with the entire engine management side using the current fuel system and Ross crank trigger setup all controlled from the Elitec 2500. The Ross trigger with the GT101 hall effect sensors I absolutely rate 10/10, unlike the heap of shit NZ wiring cam trigger on the white 32. I will elaborate on that later, but they are no replacement for a real crank trigger setup.
Found a few pics from when I was moving away from the Bosch 044s to the AEM setup with upgraded 10mm2 wiring, 2 x 400lph staged externals, dual speedflow check valves and 340lph lift pump all throungh AN8 200 series lines, basically binning the existing mismatched and poorly installed Willall racing setup. I really expected better from them as their setup caused me nothing but dramas. Note the new pump power supply 10mm2 wiring in comparison to 2.5mm2 existing - big difference.
IMG_20210426_135029_5.thumb.jpg.41c9cfd97a39d80beaca173a4a75ed06.jpgIMG_20210426_160640_1.thumb.jpg.1634b2e5fd8c81d682a344f32ecd0185.jpg
Next thing on the agenda was to fit the Turbosmart OPR T40 turbo oil reg. I've been putting it off because of the fittings and stuff I had to figure out that was required for install, and I'm glad I hadn't fitted it yet. OPR T40 won't be going on, ordered 2 of these below today and will be removing the T40 from the white 32 too.
https://www.turbosmart.com/product/opr-v2-turbo-oil-pressure-regulator/
  • Like 3
Modernisation of pumps, less heat, less noise.
Yeah I'm going to rip off my v1 OPR valve too at some stage and replacing it with the V2 OPR to reduce the hose clutter!
I actually think the old T40 on the white 32 is increasing crank case pressure increasing breathing too.
Think about it - any oil pressure in excess of 40psi is being fed back into your sump pressurising it. Normally you only have your low pressure turbo oil return and block oil passages gravity feeding back to the sump. With the T40 you are adding potentially 60psi+ with a Nitto pump back into the sump - this can never be a good idea adding to crank case pressure.
Quite possibly, I agree with your theory on that one!
I probably don't see these issues with the other band aids on top (sump/head breather/drain, sump to catch can breather/drain).
White 32 has the head breather / sump vent and decent catch can setup but still retains the stock rocker cover baffles. I've always thought it breathes more since the T40 install, so will be interesting to compare. Definitely breathes more than the blue 32, which has all that mentioned above but additionally has the Mines rocker cover baffles and 2nd pre catch can acting as an oil / air separator but also doesnt have the T40.
  • Like 1
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
