Hi
Can someone help confirm if its a one way valve or a restrictor that sits in the Turbos Intake to Rocker Cover (passenger side) on an Rb26?
I'm running a plumb back Oil/Air separator and was just wondering if i can piss that off (probably not). It's doing my head in as on the turbos intake side, it's AN10 but once met the restrictor, it becomes AN12, where the hell do i find something like that.
Thanks
2 minutes ago, KiwiRS4T said:
Whatever it is you won't be needing that hose will you? Rocker cover to air/oil seperator thence to turbo intake will be all new hoses
My turbo intake is standard so i thought i could reuse that hose. (Oil/Air to that hose)
If it acts as a 1 way valve, open on boost then i will need it right?
2 hours ago, West said:
Hi
Thanks
It is a restrictor to stop the turbo sucking all the oil out of the top of the engine.  It is just a plate with a hole in the middle of it.  If you are splicing a catch can in there somewhere (Like a Nismo unit) then you still need it.
Edited by djr81
I'm running an oil/air separator, do i still need it?
Driver side PVC remains OEM
Passenger side - Cam Cover to Oil/Air - Oil/Air back to turbo intake
Yes.
Out of interest what brand of separator is it?
Ah i get it, it's sort there to restrict the suction correct? So i can machine/file it down to suit an AN10 hose?
it's a customs made from ex Havoc fab
Or just cut and reuse the bit of hose with the restrictor in it along with a male/male push lock fitting of an appropriate size.
Or turn up what you need from a bit of aluminium rod or similar and stuff it in the hose.
Or better yet get your fab bloke to weld up and drill a hole in the end of the barbed outlet fitting on the catch can.
I wouldn't have thought so. Didn't have one on my RB30DET. The design of my catch can would have  worked against sucking out oil...my exhaust didn't smoke and my sump didn't empty.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
    • Thank you for this my turbo doesn’t have the nipple so I’ll get one installed in the turbo to Intercooler piping. I’ll get everything I need and locate it all using the information you both gave and get back with an update.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
