Hey all. I've slowly been learning my way around my car and was always suspicious of the coolant piping coming from my AAC - it just looked wrong. And, it turns out it is - this picture is of my current setup. Notice the 3rd line has been blocked off.
84613925_552114178735314_5158729272705155072_n.thumb.jpg.928bec2a31df10f1e55cf69e62a5062a.jpg
My questions are as follows:
1) Why would someone do this?
2) Where is the first line meant to go exactly? I deduced from other threads/images that the middle line goes to the throttle body (currently my first line does) and the 3rd line goes to the manifold (currently my second line does), but I can't figure out where that 1st line is meant to go to.
If there isn't any obvious reason for this set up I would like to reroute the lines to their usual spot. Probably unrelated, but I stall after revving and have idle issues, and I know this coolant affects an air flow valve hence my interest.
It might have been blocked off because it was giving trouble and previous owner too stupid to fix it properly.
There's a wax pellet cold fast idle valve in there that is heated by the coolant. It will get hot anyway, after the inlet manifold gets hot, it's just slower to heat up.
The one on the right bends straight down from where it is plugged, goes down a few inches onto an upward facing nipple on the water gallery that runs along the top of the inlet manifold.
The middle one goes down and back, to I think the line that services the turbo.
The one closest to the IACV connects to the back port on the TB passthrough.
That's the way mine are hooked up, and they have not been changed.
Edited by GTSBoy
  • Thanks 1
Thanks GTSBoy, really appreciated. I definitely want to fix this, my car stays at high idle for an absurdly long time. I know where the TB coolant line and the manifold gallery nipple is, but I still can't figure out where the third line should end from your explanation. Would you be able to post a picture of your setup please?
No, because you can't see down there. It's a tangled mess of hoses. You've got the heater hoses both there, plus a couple of others.
I can take a look and see if I can work out exactly which line it hooks up to. I think it is the steel tube that comes around the back of the engine from the turbo.
There are drawings in the manual that show these pipe and hoses.
Edited by GTSBoy
Had a look see.
The middle hose actually goes down to a nipple that comes off the heater hose offtake. At the very back lower corner of the inlet manifold there is a heater hose sized nipple sticking out sideways, pointing more or less at the bottom of the brake booster. There is another smaller nipple off the back of that, facing towards the firewall. That's where the middle hose goes.
Between your explanation and this diagram I just found, I'm ready to hose it up. Cheers mate.
Edit: I found my problem. That T junction with the nipple has been replaced with a plain T junction from bunnings, no nipple. Someones done some strange stuff to this car...
Edited by CowsWithGuns
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
