10 minutes ago, Ben C34 said:
What does positive take up mean?
Feel. The effect of clutch lining frictional characteristic, which is totally subjective to every individual. My son says his clutch takes up to quickly, I think its fine. Subjective.
Edited by Rusty Nuts
https://www.sau.com.au/forums/topic/479722-clutch/#findComment-7924462
At 220kw ish pretty much any lightly upgraded clutch will suit.
If by more positive you mean it bites more suddenly as you let it out, look at the exedy puck style clutches and their billion copies. I much prefer the progressive feel of a full face clutch like that mantic one, particularly if you don't want to be stalling in traffic all day
https://www.sau.com.au/forums/topic/479722-clutch/#findComment-7924475
Have used NPC clutches for a while now for street and track cars with around the same power. Good pedal feel and haven't had any problems. A few friends are using mantics from heavy duty up to twin plates in commodores, skylines and wrx's with all saying good things.
https://www.sau.com.au/forums/topic/479722-clutch/#findComment-7924482
1 hour ago, Old man 32 GTR said:
Do Nismo make clutches for the GTST, haven’t heard a bad thing about the clutch they make for GTR, everyone who has one says better then factory feel.
https://www.rhdjapan.com/nismo-super-coppermix-twin-plate-competition-model-clutch-kit-r32-r33.html
scroll down. They’re the same part.
https://www.sau.com.au/forums/topic/479722-clutch/#findComment-7924486
yes I do also have one in the "for sale" thread ?, but the OS Giken and ORC Japanese clutches are amazing, IMO....I'm using my 4th one now, and I wouldn't use anything else.
ORC single plate will give you great solid feel and is still suitable for traffic and daily driving.
https://www.sau.com.au/forums/topic/479722-clutch/#findComment-7924511
Thanks, will look at those too.
https://www.sau.com.au/forums/topic/479722-clutch/#findComment-7924673
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
