Am disposing of my spare parts, having sold my 1989 R32 GTR and GTSt.
1. Nissan Brake Master for R32 GTR / GTSt.
Reconditioned by Trade Brake & Clutch - Resleeved with Stainless Steel and new Seal Kit.
Pressure tested.  As good as new.  From my R32 GTSt.
A new Brake Master, ex-Nissan Japan advised as A$840 [January 2020 price].
Nissan advise no longer made and last stock units selling out.
This unit - A$540 fixed.  Can post anywhere or pickup Melbourne.
2. Other - Refer Separate Threads
- R32 GTR 89-93 ABS Module 47850.  Tested on my R32 GTR - Works fine.
New price RightDrive Parts US is $2,040.83 [January 2020 price], before shipping, duty, GST.
This unit - A$1,000 fixed.  Can post anywhere or pickup Melbourne.
- R32 GTSt Turn Indicator Lamps.  Near perfect condition.
New price Nissan ex-Japan A$340 each.
Left & Right set - A$340 the pair fixed.
- R32 GTSt Bonnet Latch.  Haven't figured out a price.
- R32 Boot Lid Key Barrel Locking Flange Plate.  New.  Haven't figured out a price.  This is one epic pain to replace, but it has to be done sometimes.
- R32 Air Con. Console Module.  Part # 503722 - 0286.  Haven't figured out a price.
- R32 Wheel Center Inserts x 2.  Haven't figured out a price.
- R34 Air Con. Console Module.  Haven't figured out a price.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
