Hi,
yesterday I tried to start my GT-T the first time after upgrading to GTX3076 and Link G4+. Well, it failed.
What has been modified?
  • Link G4+
  • GTX3076 int. wastegate
  • Link 3 bar map
  • Tomei headgasket
  • Deatschwerks 600 cc injectors
  • Deatschwerks DW300 Fuelpump
  • Blitz FMIC
  • 3" catback + 3" downpipe + custom turbo elbow
  • Oil gallery restrictor
  • GFB Mach 2 blowoff
What was not done, but will come in the near future?
  • Fuel pump rewire to replace the fpcm
  • Link IAT sensor (not wired in)
  • Tomei fuel pressure regulator
  • wastegate actuator (mounting plate missing)
  • boost soleniod not installed because ot the missing wastegate actuator
  • wideband (oem narrowband installed)
Modifications to the ECU:
  • R34 GT-T base map stored to ecu
  • configured for link map sensor
  • calibration of the map sensor
  • calibration of the tps
  • deactivated temp3 input (fuel temp - was enabled in base config and causing errorcode)
  • deactivated the iat because of not being installed yet
When I turn the key the fuel pump and injectors get highlighted in green, so I think that the ecu activates them. The starter cranks the engine but with no sign of firing it up.
Could it be a problem that the iat is diasbled? should i reduce the duty cycle of the injectors? Is there any further config needed that i could check before searching for issues (ignition spark/fuel/etc)?
https://www.sau.com.au/forums/topic/479735-gt-t-link-g4-first-start-failed/
Link provide an extensive help menu.  But you need to go right through the whole tune file, make sure the sensor settings are correct, and calibrated. This includes CAS, TPS, injectors.  First time around, you will burn time.  But follow their prompts and don't leave out any steps.  Physically check connections like CAS, injectors, and coils.
It is easy to test fire the injectors and ignition without the engine running, just follow the help menu.
If you haven't got IAT wired and functional, you're going to need to work around that one, in case the settings makes the ECU think it's seeing -50 or +140C temps.
The other thing is to double and triple check all earths around the engine.  Link has a good feature to tell you when inputs are off scale and erroring too.  It's all in the help menu.
  • Like 1
Above post is good, but just to confirm, actually confirm that you have fuel, air, spark. Just because the ECU is attempting to fire the injector doesn't always mean the injector is being fired. As above, you may need to see what IAT is used when the sensor is unplugged, it will have a fail condition.
The link forum may be of more help here. At this point (and the joys of standalone ecus) your link could be running any engine.
  • Like 1
I've done some checks yesterday. Spark test was successfull but the spark plug seem to stay dry. Fuelpump is working and there is fuel in the fuelrail and pressure on the fuellines.
So I think the injectors are not getting fired in the correct way. Deatschwerks say that they are p&p for the gt-t, I'll check if that information is correct. Does anyone have more information about that? I used 21S-05-0600-6.
When I disable the iat in PcLink the ecu sets a permanent temperature of 21°C.
Edited by Finn_GT-T
As has been said the Link help file has all information needed to get it running.
Need to set trigger widest slot and trigger offset values. Depending on what fuel mode you use will depend on how you tune it. Next is injector data THIS IS IMPORTANT especially with modelled fuel. The base file is helpful but generally doesn't get it running if you have never used one or have a good understanding of how the ecu works.
You need a Wideband sensor and controller to tune, wire to a AN input or to CAN. Factory narrow band is useless. IAT is only used for corrections but is definitely a must.
May pay to get a workshop or someone who knows what they are doing to get it sorted.
Or if you need more info PM me.
Ok mates, finally I solved the riddle with the help of the injector testing function. The solution was just as simple as plugging in the connector of the injector harness...lol
Now the engine is running...not very well, but i runs.
Thank's for your help!
So here's my next question for you:
Deatschwerks provides the following data sheet:
https://www.deatschwerks.com/sites/www.deatschwerks.com/files/DATA/injectordata/21S-XX-0600-XX%20Injector%20Characterization%20Summary.pdf
I already adjusted the dead time table in PcLink. But where do i put the values from the "Pulsed Flow Data"-table of the data sheet? Is that the right data for the "injector short pulse width adder table"?
Edited by Finn_GT-T
I don't know how it is done in Link. You might have a single percentage adjustment number to put in, or there might be several points you need to fill. Whatever it is, you are looking to bump up whatever the ECU thinks it should do for a pulsewidth by a small amount at low pulsewidths to account for the fact that injectors don't flow as well as they "should" at low pulsewidths.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
