Hi,
Unfortunately, the time has come to sell my pride and joy, my 1993 R32 GTR. I have owned various R32’s over the last 20 years leading up to the purchase of my dream car. Unfortunately, this car doesn’t fit into my life anymore and its time for someone else to enjoy it.
I purchased the car in 2013 and the car was imported into Australia in 2011 and I am the third Australian owner. I have spent the last six years lovingly restoring the car. Car has not been tracked/raced.
Year: April 1993
Colour: Spark Silver Metallic
Mileage: 110,000kms
Price: $60,000 negotiable
Exterior
-    Genuine N1/Nismo bodykit
  •     3-piece OEM plastic sideskirts
  •     OEM Vents in front bumper
  •     OEM Rubber bonnet lip
  •     Boot lip. Note: genuine lip has been replaced with an aftermarket fibreglass lip. OEM rubber lip was too far perished to be repaired.
-    Car had some fading on the roof as is common on these cars. Car has had a professional, glass out respray of the roof and respray of some of the plastic components:
  •     Front lip
  •     Bonnet lip
  •     Side mirrors
  •     Taillights
  •     Painting and fitting of new boot lip
  •     Rear spats of sideskirts
  •     New trim around rear glass
  •     New OEM seals for rear wing
    Rest of car is in original paint and in excellent condition
-    N1 non-projector headlights. Will supply original projector headlights
-    New weather strip along top of doors
Interior
-    Replaced dash with one that is bubble free
-    White Nismo 320km/h cluster with new clear cover and Nismo white triple gauges with new surround. Will also supply original stock triple gauges and a spare standard cluster
-    Dash mat
-    Aftermarket shift knob, shift and handbrake boots
-    Momo Sport steering wheel and genuine Nismo old logo horn button. HKB HICAS compatible boss
-    Rare Nissan accessory knee pads for drivers door and centre console (not fitted)
-    Seats in good condition with no rips or tears
-    Unmarked carpet
-    Excellent condition door trims – new door handles, retrimmed map pockets
-    Original floor mats
-    New quarter window interior trim
-    New retrimmed black parcel shelf with OEM speaker covers.
-    Pioneer head unit and Pioneer/Kenwood speakers
-    Central locking,  3-point immobiliser and alarm
-    Working Air Conditioning/Heating
Engine/Transmission
-    Stock RB26 and turbos
-    Has had major service at 106000kms:
    o    new timing and ancillary belts, new idler/tensioner pulleys, new water pump. All OEM parts
    o    New OEM cam cover gaskets
    o    New front main seal
    o    Coolant flush, new coolant
-    Engine serviced using Penrite Racing 10/40W oil
-    New Wiring Specialities Coil Pack loom
-    Apexi N1 front pipe, stock cat and genuine Nismo old logo Weldina cat back exhaust
-    Replaced clutch:
    o    New Exedy standard replacement clutch
    o    Rebuilt clutch slave master cylinder
    o    New clutch master cylinder
    o    Replaced transmission and transfer case fluid
    o    New rear main seal installed
Driveline
-    HICAS lockbar installed. Hydraulic feed to HICAS from Power Steering pump routed through P/S cooler. No modifications to P/S pump and HICAS delete is reversible (will supply HICAS rack)
-    New OEM rear bushes HICAS balljoints
-    New front driveshaft CV boots
-    New Whiteline standard replacement front upper control arm bushes
-    New OEM King Pin bearings
-    New OEM castor bushes
-    New OEM front swar bar links and mounting bushes
-    New OEM front inner tie rods
-    New aftermarket front outer tie rods
-    Standard shocks/springs
-    Standard brakes/rotors. Machined front rotors and QFM FMX Brake Pads. New brake fluid
-    Professionally rebuilt steering rack - new seals, re-chromed steering shaft, nolathene mounting bushes.
-    GKtech Polyurethane steering shaft spacer
-    Front and rear Nismo old-logo strut braces
-    Genuine BBS LM 17x9 + 20 two-piece wheels with new Kumho tyres
Original forged wheels to be sold with the car – wheels are resprayed with tyres that have good tread (cheap tyres though)
Serious enquires please by PM only. No swaps and willing to negotiate on genuine, reasonable offers after viewing, in person.
Jason
Edited by gts25
https://www.sau.com.au/forums/topic/479765-fs-1993-r32-gtr/
1 hour ago, gts25 said:
well spotted..
The young guy just purchased it, was chilling with his girl at the Hive.
Would have prefered to be driving that old girl and not the G-Bagon of slow.
Edit: actually, I would have rather been in my 86 ?
https://www.sau.com.au/forums/topic/479765-fs-1993-r32-gtr/#findComment-7925044
1 hour ago, junkie said:
Very tidy... compared to some other junk on sale for similar prices
It was really clean looking and very nice when I had a sneaky look around it.
Pretty quite too as it sneaked away.
You don't see many that good anymore.
Hell, I haven't seen one that good for years.
https://www.sau.com.au/forums/topic/479765-fs-1993-r32-gtr/#findComment-7925050
  • 1 month later...
    • Updating results following our SR20det project. Data collected form improves future turbocharger making and high flowing services. So far differences between G and GT series turbine wheels, we are in the process of making a new turbine, the aim is for better mid top range flow without gain too much lag.  Result is back to back comparison of G25-660 and GTX2867 spec turbochargers on the same car, nothing changed apart from turbocharger. Both tuned to knock limit from pump 98 fuel (US Ron93). GTX2867 was about 400RPM more responsive making 255rwkws while G25-660 made 17 extra Kws with wider spread of torque after 4500RPM finishing off at 272rwkws.
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
    • Given that you have seen the dash indicator work briefly, then it would seem like you have a simple wiring problem. What happens when you simply jumper the wires on the "steering wheel switch"?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
