Hey what's up y'all, I'm new to the fourms but came on here due to frustration and a misfiring RB26. My 1992 Skyline GTR has a misfire that seems to be random. It does not happen upon could start from what I can tell. Checked the computer codes and they flashed all clear. I pulled the plugs and saw they were covered in black soot, some worse than others but all generally dirty. Replaced them with some iridium plugs from NGK gapped at .8, and that didn't fix it, then put some used but nice Splitfire coils on it, which seemed to maybe help a little but it could be placebo, also seemed to not wanna start with those coils in and low idle. The car is drivable but feels down on power and the misfire is pretty constant throughout the rev range. Only other thing I notice is she spits black smoke and it leaves these carbon specs all over the rear end. Maybe she's running too rich? I'm stumped and don't wanna put any money into it until I know what's wrong. Anyone have an idea? Thanks alot!
https://www.sau.com.au/forums/topic/479778-r32-gtr-random-misfire/
2nd hand coils are not a diagnostic tool.
The other half of the ignition electronics is the igniter pack. It sits up on top of the motor getting cooked for 30 years.....it doesn't last forever.
The other other half is the coil pack wiring loom/connectors.
The other other other half is...how healthy is your alternator, battery voltage, when running?
The other other other half is that it could be a whole bunch of other things, from worn out CAS bearings, to an intercooler pipe/hose blown open (and hence running rich). But I would bet that the running rich shit is simply caused by the missing. If the fuel don't burn, because it wasn't lit, it looks rich.
Well that's my problem, I've done a lot of research but nothing really points to how I can test it to be sure. Voltage should be fine, is there any way I can pin point something like the harness or igniter before spending money on them?
Take to a mechanic that has a dyno so you can test it under load with gas analyser up the spout, and look for spitzensparks around the coils and pull coil plugs off to see which is missing and then swap stuff around to see if the miss follows the coil or stays with the cylinder. And then swap to known good coils and/or ignitor. Just the usual things.
There is nothing more frustrating than remote control misfire diagnosis. Nothing beats having someone who knows what they're lookign at actually look at it while it's running.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
