xmanz Posted February 19, 2020 Share Posted February 19, 2020 Am i unlucky in the fact my 07 v36 at only 63,000k has done a head gasket as bubbles come up and push water out of radiator. So is this just a thing thats happened or what may cause this? probly looking at 2500 nz thanx ill no go and be depressed...:) Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/ Share on other sites More sharing options...
DashyyPC Posted February 19, 2020 Share Posted February 19, 2020 1 minute ago, xmanz said: Am i unlucky in the fact my 07 v36 at only 63,000k has done a head gasket as bubbles come up and push water out of radiator. So is this just a thing thats happened or what may cause this? probly looking at 2500 nz thanx ill no go and be depressed...:) You may be unlucky as to the fact that your clock is probably wound back if the head gasket is done at "63k" Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925034 Share on other sites More sharing options...
xmanz Posted February 19, 2020 Author Share Posted February 19, 2020 its not wound back it came direct from japenese showroom 400k on clock certified Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925035 Share on other sites More sharing options...
Ben C34 Posted February 19, 2020 Share Posted February 19, 2020 then yes you are unlucky. How well did you look after the car? ever change the coolant? when did you buy it? Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925037 Share on other sites More sharing options...
xmanz Posted February 19, 2020 Author Share Posted February 19, 2020 the car has been maintained at every maintaince schedule last big one was all brake fluid all coolant auto trans filter engine filter oil etc. i bought it in 2007 but its used only for longer trips Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925042 Share on other sites More sharing options...
DashyyPC Posted February 19, 2020 Share Posted February 19, 2020 Doesnt mean its the headgasket though. Just means air has gotten in at some stage, Loose/Worn radiator cap seal etc Sure headgasket is the most common here but doesnt 100% mean it is. Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925045 Share on other sites More sharing options...
KiwiRS4T Posted February 19, 2020 Share Posted February 19, 2020 4 hours ago, xmanz said: Am i unlucky in the fact my 07 v36 at only 63,000k has done a head gasket as bubbles come up and push water out of radiator. So is this just a thing thats happened or what may cause this? probly looking at 2500 nz thanx ill no go and be depressed...:) Where do you live? Should be able to fix that for less than 2.5K Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925048 Share on other sites More sharing options...
GTofuS-T Posted February 19, 2020 Share Posted February 19, 2020 so coolant has been changed recently and now it's got bubbles... perhaps it wasn't bled properly? i though headgasket results in oil/water mix not bubbles? Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925051 Share on other sites More sharing options...
The Max Posted February 19, 2020 Share Posted February 19, 2020 8 hours ago, xmanz said: Am i unlucky in the fact my 07 v36 at only 63,000k has done a head gasket as bubbles come up and push water out of radiator. Just air bubbles? Have you considered that maybe you just have air trapped in your coolant and not a blown head gasket? Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925053 Share on other sites More sharing options...
GTSBoy Posted February 19, 2020 Share Posted February 19, 2020 Acid test the coolant. Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925056 Share on other sites More sharing options...
xmanz Posted February 20, 2020 Author Share Posted February 20, 2020 i took it to a reputable mechanic who pressure tested the system and his advice was the next stage put air compessed into cylinders which will tell the truth i guess Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925105 Share on other sites More sharing options...
GTSBoy Posted February 20, 2020 Share Posted February 20, 2020 No, the next step is to use a coolant tester to find out if there is CO2 dissolved in the coolant, forming acid, which tends to be proof positive of a blown headgasket blowing combustion products into the coolant. 1 Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925110 Share on other sites More sharing options...
The Max Posted February 21, 2020 Share Posted February 21, 2020 (edited) Agreed. If there are no obvious signs of oil mixing in with the coolant, the coolant itself needs testing first. It'll be a lot easier than what your mechanic is proposing. He's jumping the gun a bit there. Edited February 21, 2020 by The Max Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925161 Share on other sites More sharing options...
xmanz Posted March 12, 2020 Author Share Posted March 12, 2020 (edited) On 2/19/2020 at 7:43 PM, KiwiRS4T said: Where do you live? Should be able to fix that for less than 2.5K im in napier the guy thinks upwards to 3 grand and seems to think the engine may have to come out or drop the front away!!! he may be reading wrong stuff.. so to do head gasket does the whole timing covers have to come off? or can heads be done insitu.... thanx guys Edited March 12, 2020 by xmanz spelling Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7926380 Share on other sites More sharing options...
GTSBoy Posted March 12, 2020 Share Posted March 12, 2020 1 hour ago, xmanz said: so to do head gasket does the whole timing covers have to come off? Well, yeah, most of it - certainly at least the top part. The VQs are chain driven, yes? But pulling timing covers off is not the difference between affordable and not. Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7926387 Share on other sites More sharing options...
xmanz Posted March 12, 2020 Author Share Posted March 12, 2020 16 minutes ago, GTSBoy said: Well, yeah, most of it - certainly at least the top part. The VQs are chain driven, yes? But pulling timing covers off is not the difference between affordable and not. i got a bit lost on last part of your statement ( But pulling timing covers off is not the difference between affordable and not.) im trying to assertaian if the front has to drop away and take radiator out for acess cheers Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7926389 Share on other sites More sharing options...
GTSBoy Posted March 12, 2020 Share Posted March 12, 2020 30 minutes ago, xmanz said: front has to drop away and take radiator out for acess Do you mean remove the front of the car? Hell no. Take radiator out? Quite possibly. But that's not expensive work. Neither is removing the timing covers. That's what I meant when I said "But pulling timing covers off is not the difference between affordable and not". If it adds an hour to the job it's an extra hundred buck or so, right? Not an extra $500. Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7926393 Share on other sites More sharing options...
xmanz Posted March 12, 2020 Author Share Posted March 12, 2020 28 minutes ago, GTSBoy said: Do you mean remove the front of the car? Hell no. Take radiator out? Quite possibly. But that's not expensive work. Neither is removing the timing covers. That's what I meant when I said "But pulling timing covers off is not the difference between affordable and not". If it adds an hour to the job it's an extra hundred buck or so, right? Not an extra $500. ok that sounds not too bad is the timing cover one piece or is there a top section thats not behind pumps and things... btw i had a search for v36 workshop manual and g36 for 2007 cant locate any ideas Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7926397 Share on other sites More sharing options...
GTSBoy Posted March 12, 2020 Share Posted March 12, 2020 2 minutes ago, xmanz said: is the timing cover one piece or is there a top section thats not behind pumps I dunno. I'm an RB user. Google image search and have a look. Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7926398 Share on other sites More sharing options...
370 GTS Posted March 12, 2020 Share Posted March 12, 2020 When it is all fixed I would have the rad fan checked (I would think they are a clutch fan) blow a head gasket in our D.Max at 130K and five years old. Don,t rely on your temp guage I ran a scanguage 11 in our Isuzus and that how I seen the temp rise, nothing showed this on the vehicles temp guage. Link to comment https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7926401 Share on other sites More sharing options...
