19 hours ago, xmanz said:
ok that sounds not too bad is the timing cover one piece or is there a top section thats not behind pumps and  things...
btw i had a search for v36 workshop manual  and g36 for 2007  cant locate any ideas
https://ownersmanuals2.com/d/52111
2008.
pretty close
  • 1 month later...
update on my troubles
mechanic checked all the cooling system over..no apparent issues
went to next stage took throttle body off and compession tested it and then a leakdown test ...........both no issues
he then put back together and vac test the system    no issues\
He is a bit stumped but did say maybe the water pump is sucking air behind the timing cover  anybody seen anything like this???
he said there where bubble coming up on compession test on any of the cylinders.....    is it possible to suck air in somewhere else?
thank you
thank you
Could you rewrite this sentence please? Its a bit hard to work out what you are saying.
Did he say yes there were bubbles in the radiator when some or all of the cylinders were compression tested or no there were not?
BTW you're out on a limb in Napier - I have good contacts in Auckland but none there... and yes you  have to pull the front of the car off to get at things which is why replacement timing chains are so expensive...(so if you end up doing this good idea to have the chain and chain guides checked at they are a weak pint on the VQ25).
He infered to me that winding it over doing compression test  he saw bubbles   and no matter which cylinder he did  he saw bubles these are not fine bubbles but  like a burp      btw  v36
i got the g35 manual
Ok one more question...did you watch the mechanic do the pressure test and what happened? Did the pressure go down without any sign of water spurting out?
Here is a test kit along the lines of what GTSBoy was suggesting earlier (you may be able to get a similar one cheaper from your local Repco or Supercheap) that you can use yourself:
https://www.trademe.co.nz/motors/car-parts-accessories/tools-repair-kits/other/listing-2596027845.htm?rsqid=e736fd9eb1f5494eb91b42a7ed009919-001
If this test comes out positive you have a problem. If it comes out negative (no exhaust gas in bubbles) then it is still possible you need a good bleed of the air in the system (especially if this problem arose following a service where the coolant was changed).
OR you do a good bleed now anyway: Get the front of the car as high as possible (up a steep drive, on a set of ramps, or jacked up as high as) and also find a plastic bottle (coke , milk, anything with the bottom cut off) the neck of which will fit tightly in the tube after you have taken the radiator cap off. Start the engine and turn your heater(s)  on full. Idle until the thermostat opens (you can tell by the hoses  heating up) and add water to the plastic bottle (half full will do). Continue to add water if necessary and watch for the bubbles to stop. Give it a good 20 minutes or so. If the bubbles stop put the cap back on and hopefully its cured!
BTW as a matter of interest how far can you drive the car before it overheats?
+ also open all bleed screws that you can find to get air out of trapped spots. RBs have a couple, I would guess that VQs probably would too. YOu don't just open them and leave them. Open and close them regularly while you're leaving it running to bleed up as above. Bubbles will collect at the high points as they come around the system. The screws give you the opportunity to get them out.
i didnt see the test but he said the compression was i think 190 on all no loss  and the leakdown  no issues,
btw thank you for all the info much appreciated       also the car has never overheated just hear bubble sound form behind dash when i started the car..upon opening bonnet the resivour was pretty full......so ill try the bleeding  scenario
Ok with lockdown cant get a co2 device but i sloped the car, filled the bottle half full sealed onto radiator,,,,,youl see vid 1 which is 5 mins in     video 2  12 minutes in   and video 3 20 mins.
i guess my dumb mechanic didnt do this as youl see by vid 3  it shows what i presume is indeed compression/exhaust gases into water/////   Thank you for looking, the coolent did have a bottle of some  hoodoo in it to hopefully plug leaks by mechanic,,,   last vid is when engine is switched off...
Edited by xmanz
Close it up and drive it. If it has not been overheating just keep an eye on the water level. Certainly wouldn't be pulling it apart at this stage. Worth doing it again to see if it gets less. If not definitely do the gas test. You may be able to get a kit from Repco or Supercheap on line as they are allowed to ship "essential" items.
i have to mention also  power is down and uses more fuel that what it used to....  i may want to sell in a year or so and i cant sell this..lol
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
