Hi Folks
You may be able to search for my rumblings and complaints over the years how my 1.5 way was a bit clunkier around town than your regular 1.5 way and how I wanted to fix that to no avail.
Upon finding a unicorn R34 Helical, this diff is now for sale. As I know people would want to see the center before buying a rando diff, I took the cover off and found that it was actually a fkin 2 way diff the entire time.
It was recently rebuilt from scratch to try and find "the problem" and of course there was none, which was... quite a lot of money not so well spent on my behalf, but hey this diff has been entirely rebuilt for your pleasure.
Will bolt and plug in directly to your R34. I can confirm this thing locks up HARD in both Accel and Decel scenarios.
You could use it on the street, I did for quite a long time it turns out and I did not die. However, I wouldn't recommend it for a daily.
$1200 obo.
Pickup strongly preferred!
  • Like 1
https://www.sau.com.au/forums/topic/479871-r34-gtt-nismo-2-way-diff-whole-diff/
  • 2 months later...
Fit, physically? Yes
ABS though? Your guess is as good as mine. The R34 has 2 ABS sensors one on each stub axle, the R33 has one (or none). Can you just... put the sensor into one of the ports on the stub axles?
Maybe? Yes? No? Maybe the cable won't reach/needs to be extended?
You'd be a guinea pig in that aspect.
Could you pull the center and driveshafts out of my diff, put them into a R33 ABS R200 housing? Uh, maybe? Again not sure. Depends on your confidence and how much you care about ABS as far as I know...
No. Different pulse rates vs speed.
Yes, of course. Although you will almost certainly end up paying for diff setup here, as the pinion from Greg's diff will have to be put onto the R33 diff's input /pinion shaft, because I think that the diffs with front ABS have a longer housing*.
(I might be wrong, but it looks like it in various piccies I've seen.)
I was really hoping GTSBoy would find this thread, because all I can confirm 100% (with no taking anything apart, bolt/unbolting centres) is that it'll go into a 34.....TURBO ?
  • 1 month later...
Cmon folks, surely someone wants to do a skid.
Technically this is a 1.5 way, it's just everyone thinks 1-ways are actually 1.5 ways.
  • 4 months later...
It would appear noone wants to do a skid. This is now a 1.5 way. It's always been a 1.5 way, because anything between a full 45 degree 2 way, and a 90 degree 1 way, is a "1.5" way though it could easily be referred to as a 1.2 way or 1.75way or 1.9way.
If you have a 34 get a diff. Specifically this one.
It is 4.111 (or 4.083 if it originally came for an auto) which has.. 0.5kmh difference between the two in any one gear.
  • 6 months later...
Sorry no - It's been sold, I didn't close the thread off due to bumping it from oblivion seemed un-necessary.
It has gone to a new home, namely a madman who is putting a E60 V10 into a R33.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
