Hi, I am looking to set up a flow test bench to perform some validation of some fuel system components.
I have some air flow meters sitting here (specifically Z32 AFMs) that i would like to use to meter the air entering the combustion process to validate the fuel flow against that, based on resuting lambda data.
I have found the MAF scaling tables in nistune, that are read in (0.08-5.12v) that scale between 0.07 to 100% of maximum MAF flow. my question is what 100% corresponds to in actual airflow in g/s?
if anyone else has accurate calibration data for any MAF sensors that would be helpful.
thankyou.
I don't think that you will get that information to the level of accuracy that you want.
If it were me, I would create a way to manually calibrate the AFM. That would involve inserting it into a suitable (long) length of 3" tube (assuming 3" is the right size - choose the appropriate size for closest match to the AFM body) and do some manual measurements with a small plain pitot. The way to do that would be to ensure that the pipe upstream of the AFM was at least 15x the diameter of the tube, (so, at least 1200mm long) and drill a small hole to allow pitot insertion at a point >5D upstream the AFM and >10D downstream the inlet end. Probably put a bellmouth on the inlet end too, to give it the best chance of developing a clean velocity profile by the time it gets to the pitot location. Do a 5 or 7 point equal area traverse. If you're really keen, have another hole at right angles to the first to permit a 2nd traverse across the other plane. Convert all differential pressure readings to velocity then average all those values to obtain average velocity. (Also need to measure temperature and static pressure at the measuring location to calculate air density for the velocity calc). Then with the average velocity and the density in hand, simply convert to mass flow rate.
You can do this at a variety of flow rates to compare against the AFM voltage reading. Be aware though that plain pitot measurements are not good below 5 m/s and the measurement error starts to climb as you go below 10 m/s.
You could use some other sort of velocity measuring device. If you have a very small vane anemometer available (say, 15mm diameter head) and you had good calibration data for it (they always read a little low) you could use that to go direct to velocity. Ditto if you know someone with a proper hot wire anemometer, which is the exact same tech as the AFM you're trying to calibrate, conveniently.
If you can't access any probe style velocity measuring tools, you could make an orifice plate (in accordance with the appropriate standard, which I think is BS 1042, or one of the equivalents) and measure the differential pressure across that. The beauty of the orifice technique is that you can make a number of different sized orifices so that you can extend the bottom end of the measuring range (by using smaller orifices).
Any dP measurement will require that you be able to measure dP. The best/easiest way is with a suitable digital manometer, but you can always make an inclined manometer with a plank and some hose and you would be surprised how accurate that can be.
Whatever length of tube you had the AFM in for these manual measurements (both on the inlet side and the outlet, which could be shorter) would be best retained as a permanent part of your test rig, because it will be a part of the calibration of the AFM.
ok so I've done some more digging and have come accross this nismo plot of the AFM curve. I have interpolated several points that cross the grid neatly and it seems to line up with the nistune calibration curves.
will see how this goes first and build a manometer/oriface plate/pitot etc if needed. it appears that using a stock RB-26 AFM will be better for my needs as it gives much better flow resolution down low.
nismo graph of voltage vs flow:
nismo_afm_ed.jpg.19b31d80f9f19f8a2ec6e2b
Voltage (v) % Scale g/s
0.080 0.073 0.356
0.160 0.073 0.356
0.240 0.073 0.356
0.320 0.073 0.356
0.400 0.073 0.356
0.480 0.073 0.356
0.560 0.111 0.542
0.640 0.159 0.772
0.720 0.218 1.061
0.800 0.290 1.410
0.880 0.377 1.833
0.960 0.487 2.367
1.040 0.618 3.005
1.120 0.777 3.777
1.200 0.974 4.734
1.280 1.196 5.817
1.360 1.445 7.026
1.440 1.723 8.377
1.520 1.982 9.638
1.600 2.373 11.537
1.680 2.753 13.385
1.760 3.182 15.470
1.840 3.658 17.785
1.920 4.179 20.322
2.000 4.747 23.082
2.080 5.362 26.072
2.160 6.055 29.441
2.240 6.833 33.225
2.320 7.671 37.298
2.400 8.582 41.728
2.480 9.572 46.543
2.560 10.634 51.707
2.640 11.765 57.205
2.720 12.978 63.103
2.800 14.269 69.380
2.880 15.628 75.991
2.960 17.073 83.017
3.040 18.601 90.444
3.120 20.217 98.302
3.200 21.930 106.634
3.280 23.737 115.418
3.360 25.669 124.812
3.440 27.681 134.598
3.520 29.770 144.755
3.600 31.972 155.462
3.680 34.275 166.658
3.760 36.698 178.440
3.840 39.240 190.801
3.920 41.920 203.830
4.000 44.746 217.571
4.080 47.710 231.987
4.160 50.820 247.108
4.240 54.066 262.889
4.320 57.447 279.331
4.400 61.001 296.611
4.480 64.704 314.618
4.560 68.548 333.308
4.640 72.547 352.755
4.720 76.704 372.966
4.800 81.025 393.978
4.880 85.512 415.791
4.960 90.167 438.428
5.040 94.995 461.904
5.120 100.000 486.240
Edited by burn4005
  • Like 2
0.080 0.073 0.356
0.160 0.073 0.356
0.240 0.073 0.356
0.320 0.073 0.356
0.400 0.073 0.356
0.480 0.073 0.356
0.560 0.111 0.542
0.640 0.159 0.772
0.720 0.218 1.061
0.800 0.290 1.410
0.880 0.377 1.833
0.960 0.487 2.367
1.040 0.618 3.005
1.120 0.777 3.777
1.200 0.974 4.734
1.280 1.196 5.817
1.360 1.445 7.026
1.440 1.723 8.377
1.520 1.982 9.638
1.600 2.373 11.537
1.680 2.753 13.385
1.760 3.182 15.470
1.840 3.658 17.785
1.920 4.179 20.322
2.000 4.747 23.082
2.080 5.362 26.072
2.160 6.055 29.441
2.240 6.833 33.225
2.320 7.671 37.298
2.400 8.582 41.728
2.480 9.572 46.543
2.560 10.634 51.707
2.640 11.765 57.205
2.720 12.978 63.103
2.800 14.269 69.380
2.880 15.628 75.991
2.960 17.073 83.017
3.040 18.601 90.444
3.120 20.217 98.302
Message sent mate.
