I know you're all groaning but read on and you will at least get where I'm coming from. Rb20det. Idle issues. Fuel efficiency issues. Car runs like a lada niva issues. Starting issues. Engine power cutting issues. All intermittent (some can be for months, some for minutes, some disappear forever without me changing a thing). All of varying degree. Smiling yet? My question is when and why to reset ECU? Should it be done after any component is replaced like regapped plugs and even air conditioning compressors and if not when? These are not upgrade parts I'm talking just straight replacements that you're hoping has failed (like I'm hoping mine is afm). Should it be done as a ctrl-alt-del troubleshoot BEFORE I start blaming parts or can it irretrievably make things worse?
Edited by LINK17
Change title
No, and never under those sorts of changes.
No. Because it doesn't really do anything. It just forgets the long term fuel trims, which will not stay there very long if there is no mechanical/electrical problem causing them in the first place. If the problems are still there, then a reset ECU will go back there reasonably quickly anyway.
Dont forget that even if u get a new ECU or "Reset" the ecu you have... your engine is 20+ years old.
I would recommend doing some good general maintenance that will defiantly help your car to run right and healthier , cause to me it sounds like you may have a host of small things that all together , make your car run like shit
You should start with:
- New Spark Plugs
- New Coil Packs (strongly recommend)
- New Fuel filter (you can easily get one over the counter for a Patrol, Xtrail, Etc.)
- Replace or atleast clean your Injectors.
- New O2 sensor (this can improve Fuel Efficiency)
- Clean your Idle Air Controller (you can check out youtube)
- A dying or maxed out AFM can give you sudden and instant power/engine cuts when driving
- Check your Vac lines (especially the ones that run to your IAC)
- Boost leak Test
- If you're running a Fuel Pressure Reg, make sure you run the right PSI
- Buy a wide band gauge so you can see whats up when your problems occur
Once you've done these things you should the also take a look and re-set your Ignition Timing (consult with Service Manual and not forums or mates)
While your at it with the ignition timing and service manual you can take a look at your TPS and re-set it, this can also affect your idle and how your car runs
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
    • Absolutely. Look very closely at the photo (of yours) that I took my second snip of. See how the sill is thicker material right behind the pinchweld, where the two notches are? That is the factory reinforced area for lifting. That pad is supposed to carry the weight. The factory jack (go look at it, and how it interfaces with the car at the pinchweld) shows you exactly how the load is carried from the car to the jack to the ground.
