I know you're all groaning but read on and you will at least get where I'm coming from. Rb20det. Idle issues. Fuel efficiency issues. Car runs like a lada niva issues. Starting issues. Engine power cutting issues. All intermittent (some can be for months, some for minutes, some disappear forever without me changing a thing). All of varying degree. Smiling yet? My question is when and why to reset ECU? Should it be done after any component is replaced like regapped plugs and even air conditioning compressors and if not when? These are not upgrade parts I'm talking just straight replacements that you're hoping has failed (like I'm hoping mine is afm). Should it be done as a ctrl-alt-del troubleshoot BEFORE I start blaming parts or can it irretrievably make things worse?
Edited by LINK17
Change title
No, and never under those sorts of changes.
No. Because it doesn't really do anything. It just forgets the long term fuel trims, which will not stay there very long if there is no mechanical/electrical problem causing them in the first place. If the problems are still there, then a reset ECU will go back there reasonably quickly anyway.
Dont forget that even if u get a new ECU or "Reset" the ecu you have... your engine is 20+ years old.
I would recommend doing some good general maintenance that will defiantly help your car to run right and healthier , cause to me it sounds like you may have a host of small things that all together , make your car run like shit
You should start with:
- New Spark Plugs
- New Coil Packs (strongly recommend)
- New Fuel filter (you can easily get one over the counter for a Patrol, Xtrail, Etc.)
- Replace or atleast clean your Injectors.
- New O2 sensor (this can improve Fuel Efficiency)
- Clean your Idle Air Controller (you can check out youtube)
- A dying or maxed out AFM can give you sudden and instant power/engine cuts when driving
- Check your Vac lines (especially the ones that run to your IAC)
- Boost leak Test
- If you're running a Fuel Pressure Reg, make sure you run the right PSI
- Buy a wide band gauge so you can see whats up when your problems occur
Once you've done these things you should the also take a look and re-set your Ignition Timing (consult with Service Manual and not forums or mates)
While your at it with the ignition timing and service manual you can take a look at your TPS and re-set it, this can also affect your idle and how your car runs
    • Yeah, the thread is only nearly 20 years old.
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
    • Went to a drift practice day at a local circuit (held on the reserve parking area behind the grandstand) for the first time in about 15 years. Some kei cars were drifting as well, a not so surprising Suzuki Carry truck, and two 1st gen Daihatsu Copens that were converted to rear wheel drive(!) using Daihatsu Boon X4 transfer case, prop shaft and rear diff, obviously omitting the front driveshafts. They looked really fun to slide. I heard that they cost "about half" as much as a Nissan Silvia etc to run.  On the track 'Tech M' a local BMW tuning garage had a customer track day. Mainly recent models but there was one E36 which looked ancient among all the current models. It was cool watching the drifting and then turning around and seeing random people thrashing their M3/4s  central-circuit-drift-practice-2025-05-18-long-yt.mp4
    • I prefer it with those wheels (sacrilege?) 😋 Here's a photo of a fully original one for reference. The price is $350K....
    • I would like to keep it around 15k but if I need more to make it reliable and not have to worry about the car breaking I can go more. It's my project car so I'm just trying g to figure out what needs to be in it i know basic things like turbo cams injectors I'm just unsure of the size and the specifics so I'm spending alot of time on Google and its mostly rb25 and rb26 not alot on neo
