2 hours ago, MoMnDadGTR said:
love it. flex fuel setup on e85? im using water meth injection on my car. works great with the haltec. seems like the boys down under arent going this route but i can get it for cheap and it keeps my engine parts clean...
I’ll be running on pump fuel for now and then maybe next year set it up for e85.
water/meth kit works wonders mate really cheap stuff that works great.  i dont know about down under there but we have an AEM kit with safety backup and ive been running it solid for years. my opinion better setup than e85 for what its worth.
  • Like 1
Can you please send me a link of this item? I’ll have a look and research about it!
here is the base kit from aem...i know its not a down under piece but we use this alot around here on big power 2j's and rb's. keeps your engines valves crazy clean...my nossle is in my manifold. need a flex fuel sensor of some kind obviously haha....can run crazy boost if your motor is built for it with this kit. really cheap stuff too, i buy it at a farm supply shop in town. im sure some guys are gunna say this option isnt safe but it defintily is and works great. tried and tested mate. upgrade to a bigger tank to if you go this route.
Mods update
-Garret GTX3582r Gen2 T4 turbocharger
-ID1300cc Injectors
-6boost manifold
-JUN 272 Stage2 cams
-CP forged pistons and conrods
-N1 oil pump with Reimax Oil pump gears
-N1 water pump and timing kit
-HKS cam gears
-TOMEi sump baffle
-ARP Main stud kit, crankshaft main bearing cap stud kit
-Exedy twin plate racing clutch
-Custom oil catch can
-Apexi Power FC D-Jetro
-100mm Intercooler
-PWR aluminium radiator
-JJR Heater and cooling silicone hose kit
What do you guys think? Will I hit 600hp at the wheels?
  • 5 weeks later...
Update:
Taking the car out of the mechanic shop and getting it towed to another mechanic shop.
Been 5 months with no progress at all. disappointed but it is what it is.
Will be in better hands next week.
1 hour ago, oktaytrz said:
Update:
Which shop?
13 minutes ago, oktaytrz said:
Bad news guys..
apparently the cams are Stock cams not Jun 272.. I’ve been misled. So I am in need of some drop in cams.
was thinking of Tomei Type B Poncam 262. Any thoughts?
Yep keep the stock cams with adjustable gears.
  • Like 1
I’m really leaning towards Tomei Poncam Type B 260 9.15lift. Might as well get it done as I’ll be running flexfuel next year means more power. Will need the cams anyways
UPDATE:
Painted the inside door jams and boot lid in 326 crystal white colour. today I will be putting the doors and the boot back on before sending the car back to mechanics.
Parts Update - ordered below parts
-Haltech Platinum Pro (plugnplay)
-ATI Balancer 750hp rated
-Brand new coil pack loom
Hi Ladies/Gents,
Need some opinions / recommendations
as we're aiming for 550-600hp on pump fuel (98), I am having to think of ways to improve the life of my gearbox lol. any tips would highly appreciated.
I have a r33 gearbox btw.
Thank you
Also, any predictions of power outcome with below mods please? car will be run on pump fuel.
Updated Mod List
Garret GTX3582R Gen2 0.82ar
6Boost Exhaust Manifold
Tomei Type B Poncams
CP Forged Pistons and Spool conrods
OS Giken Cam Gears
ATI Balancer 750HP rated
ID1300cc Injectors
Haltech Platinum Pro ECU
Tomei Sump Baffle
N1 Oil Pump with Reimax gear set
N1 Water Pump
Cosmetic gaskets
PWR Racing Radiator
Turbosmart Waste Gate
ARP Main Stud Kit
ARP Crankshaft Main Bearing Cap Stud Kit
Greddy Electronic Boost Controller
4’ HKS Super Dragger Exhaust
Exedy Twin Plate Racing Clutch Kit
Frenchies Single Pump Intank Fuel Pump Kit
UPDATE:
Decided to go flexfuel ? since I bought the Haltech Platinum pro. Will need an external map sensor to turn the boost up and a flexfuel sensor.
Engine progress pics to come next week.
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
