On 07/07/2020 at 1:37 PM, oktaytrz said:
Update
Getting Haltech Elite 2000 instead of the Platinum Pro.
this car is costing a looooot more than my expectations ?
Whatever you first “budgeted”, ATLEAST double it to begin with.
  • Like 2
  • Haha 2
On 11/07/2020 at 5:13 PM, Shyboy said:
Welcome to the rabbit hole ?
I'm going to have to agree with the statements above ?
UPDATE:
-Cams went in this week and valve clearances etc all checked.
-Ordered Gates Racing Timing Belt
-Painted the brake booster and all other small bits and pieces - will upload pics soon.
-Engine is scheduled to go back in by end of next week (hopefully) lol
Am thinking of buying Tuff engine mounts. would appreciate any feedback on these before I purchase it.
http://musclegarage.com.au/index.php?route=product/product&product_id=117
broke nismo ones frequently, tuff mounts are the way to go
Purchased the Tuff mounts :)
I have a question for everyone here..
Haltech Elite 2000 vs Link G4 Fury plug in.
What are the differences, advantages and disadvantages? there's a significant price difference between the two.
I have not used a Haltech,
However have a Link G4+
I find the functionality and interface easy for myself to setup different things i.e. launch control adjust rev limits and boost by gear.
Logging is comprehensive and easy to use / download / analyse.
Ultimately depends who is tuning your car and what they want to use.
  • Thanks 1
Who is your tuner mate if you don’t mind me asking?
Rob @ SSC
He isn't a very big shop, but very thorough looks after a few targa guys.
Probably need to update my SAU build thread, will get to it
  • Like 1
UPDATE:
Tuff engine mounts arrived today. Will be dropping the gates timing belt to the mechanics shop today or tomorrow!
The engine should be going in this week ? more photos to follow later this week.
Started polishing the exhaust. Still have heaps to do and will have to grind the welding joint to make it look half decent.
The Fury isn't a plug-in, the plug-in is equivalent to the G4+ Xtreme (which is basically the same as the Fury but doesn't have onboard wideband control).
In all honesty, comparing ECU's can get a bit confusing at face value. You need to know what you want from the ECU. If you need specific functions like knock control, launch control, traction control, wideband control, data logging, etc, then you can look at the ECU's capabilities and pick one. This is really for guys using their car for motorsport, because that is really the only situation where you might be thinking "ok, I could shave a bit of time off if my ECU could do X or Y". For a street car, where you just want good resolution to have accurate control of the engine and perhaps some safety features, then pretty much all modern ECU's are going to be able to do it for you. This is where the advice of 'ask your tuner what he recommends' becomes pretty valid, because if your tuner for any reason feels more comfortable tuning a Haltech vs a Link or vise versa, then go with that suggestion because at the end of the day your ECU is only going to do what the guy with the laptop tells it to do. If your tuner says "whatever you like, we can tune anything", which most of them will, then pick based on your budget. Plug-ins are going to be miles cheaper to setup compared to a full wire-in, so take that into account.
My biggest piece of advice would be pay attention to how many inputs/outputs your ECU gives you. Most people will chew up AVI's very very quickly, so you want as many of those as you can get to suit your budget.
  • Like 1
Thanks for the info mate. I think I've made up my mind and going with the Haltech Elite 2000.. My tuner also recommended either Elite 2000 or 2500.
  • 4 weeks later...
UPDATE:
The Engine is in!!
Next in line is, sort out all the wiring, install the cooler, radiator etc etc and plumbing.
After that, we need to sort out the fuel system and were good to go.
  • Like 1
  • 3 weeks later...
Busy weekend for the boys in WA as everyones getting ready for Powercruise this weekend.
Hopefully more progress photos will come next week.
Current state as per below. Still need to order the fuel system, fittings etc etc.
  • Like 2
    • Hi, does anyone know how I can, or can a moderator remove this advertisement please.  Has been sold a long time ago and would like to remove references. Thanks.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
