1 minute ago, hattori hanzo said:
re exhaust, bigger is always better
See below graph of cutting the restriction out of my HKS Hi Power Silent
Will decide very soon!
awesome results man👌
yeah when i ditched my 3.5 and went to the 4" my egt's were much lower during hard driving, and recovery time was much better for egt as well. holds boost better in top end with my twins but wont notice that with that beefy Garrett, she gunna pull like a maniac either way....
  • Like 1
Update:
-Fuel tank is in with the frenchies kit and the fuel lines are completed
-cooler pipes, catch can and pod filter pipe is all painted in gloss black for that clean blackish look
Edited by oktaytrz
Wrong picture
More progress shots.
Whats left:
-Finish off the exhaust (trying to decide what muffler to use)
-Order Bosch 1650cc
-Install the hicas delete kit
-Replace all the fluids
-First Start
  • Like 1
Update
Muffler is manufactured and sent to Perth.
Next week we will be replacing all the fluids, installing the Red Optima battery and the muffler. First start is expected end of next week or early December.
On 17/11/2020 at 12:17 PM, oktaytrz said:
Is there a reason that the bov is pre intercooler and far away from your throttles ? It's also seems unnecessarily long and close to your wheel.
Bov is supposed to be mounted as close as practical to your throttle body, that's why the OEM put them where they are.
Your muffler also looks smaller than 3.5inch internally
  • Like 1
2 reasons: Placing the BOV near the turbo is to prevent compressor surge and we thought, if we ever need to go to engineering (if I get yellow stickered etc.) and plumb back, its a lot easier to plumb it back on the passenger side.
Here's another photo from another angle. its pretty far away from the wheel.
1 hour ago, BK said:
Boost control = wastegate via solenoid.
We are using the haltech boost control solenoid. I'm leaving the nitty gritty stuff in the hands of my very capable mechanic haha.
Excited for the first start up on Monday!
38 minutes ago, AgEr said:
Hey mate...just checked out this thread... nice build, your gonna love it. I got my car back a couple of weeks ago, running a similar setup. Made 450kw on pump and 550kw on e85.
Hi mate,
Thars great! How much boost you pushing through? 550kw is amazing! I'll be happy with 475kw!
Did you have to run in your engine for a bit?
48 minutes ago, oktaytrz said:
Hi mate,
My engine was already previously built.. just done the single turbo setup and some further supporting mods... 19psi on pump and 21psi on e85... if you haven't finished your exhaust, I would recommend getting an AES dump valve... easy power gains when open and it makes it sound like a monster with the flick of a switch...
  • 4 weeks later...
hey man sorry I've been away from the site for a bit. super happy for you mate. good guy even better car lol. side not I got my new rb26 finally stripped to long block and ready to ship for machining and building. ill pm you. engine looks great though man mate what a beast. the old white horse is gunna buck lol
  • Like 1
  • 5 weeks later...
UPDATE:
Its been a while.. started working FIFO so things are moving a little slow.
Still waiting for the paint prep to be completed before the respray. In the mean time we have an issue to solve which I think its the Gearbox input shaft. There's a rattling noise coming but couldnt not figure out the exact location. The tuner and my mechanic's first guess was the alternator bearing but we've started the car without the belt and the rattling was still there.
When the clutch is pressed in, the rattling goes away and the usual twin plate clutch noise comes which isn't too loud.  Due to be back home next Friday so I will be dropping the gearbox out, leave flywheel on, bolt up the bell housing/plug the starter and start the car to confirm its the gearbox.
Overall, very happy how the car turned out mechanically but I will be doing some more upgrades during the year so watch this space!
38 minutes ago, hattori hanzo said:
Did i miss something, how did it go on the dyno?
Running Tune went pretty good mate. The car drives pretty good, its just that rattling noise that I have to figure out (I put my bet towards the gearbox input shaft).
The only issue with dyno was the exhaust side of the engine bay paint lifting/burning off due to me not having a turbo beanie +reflective tape along that side of the engine bay lol. Turbo sits too close towards the engine LHS engine bay. Will fix that after the exterior paint is completed.
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
