On 3/7/2020 at 5:15 AM, Dil-Dog said:
I enjoy my Mishimotor Radiator with the stock Clutch fan and GKtech fan blade... but what ever you decide to do though, do NOT buy the mishimoto electric fan. its garbage and is better off meant to cool a computer or somthing.
My advice also.  Mishimoto electric fan seems designed for Antartica
Update;
Purchased a Garret GTX3582R 0.82 T4 last week from Supercheap (they had 30% off sale for $2350). I made up my mind and ill be buying Koyorad Radiator using the stock fan and shroud.
As I do more research, I come up with a lot more questions lol.
Q1: Currently, I am looking at getting the sump extension but if I can't, is it worth me buying TOMEI POWERD Oil Pan Baffle Plate? Was wondering if that would help me by any chance.
Q2: Is it worth selling the Power FC and buying Haltech Plug in ECU to run flexfuel? As mentioned previously, my power goals are at least 550-600hp atw (p.s this will be a weekend cruiser not a track car)
Q3: Anything else I should consider for a "reliable" 550hp?
Thanks guys
On 3/23/2020 at 8:26 PM, oktaytrz said:
Update;
Thanks guys
Power FC is not a limitation on power depends on how keen you are to have flex fuel. Plus its not an engine out job if you change your mind later.
Reliability is mainly down to a good build followed by a good tune.
On ‎3‎/‎23‎/‎2020 at 3:26 PM, oktaytrz said:
Update;
Thanks guys
1. In the absence of a larger capacity sump the Tomei baffle is worth having.  I ran one on the track for years whilst over filling the sump.
2. Well your set up will either be more suited to E85 or petrol. So if you need to run both then yes you need something other than a power FC.  Its much easier to find hp with E85. There are now much better ecus than APexi's 1990 version.
3. Just spend alot of time on ring selection, block preparation/blowby and work out how you are going to run the thing in from the moment it starts up.  Oh and no one has said dont waste your money on that intercooler.  Also valve springs have you got some?  Head gasket?
Thank you for your comment! Its always better to have flefuel option I guess. Good point I guess I can swap the ecu later on, but ill make sure the fuel system is e85 compatible.
7 hours ago, r32-25t said:
Don’t waste your money on a tomei baffle, nite the bullet and get an extended sump with trap doors and etc
Hard decision! still thinking about it. I won't be taking my car to tracks but as I said it is only for reliability purposes.
Engine work was done before I purchased the car but the engine never went in the car as the previous owner did not have the funds to complete the build. Headgasket, valve springs etc are all upgraded.  I have both stock and aftermarket (105mm thick) intercoolers. Which one would you recommend?
I don’t take mine to the track either and while accelerating in a straight line with the stock sump with a tomei baffle it kept tripping the engine protection due to oil surge
  • Thanks 1
http://www.kudosmotorsports.com/catalog/pump-gear-billet-chromoly-steel-reimax-suit-nissan-skyline-rb26dett-with-pump-77mm-gear-p-1981.html
ordered from this direct link parts came quick and was recommended by others on this site that know there stuff...motor out job wasn't that bad. cheers
  • Thanks 1
sorry for double post but ive ordered all my higher end parts from kudos their a great parts source for stuff like this(engine components, suspension, etc.) cheers mate definitely a good upgrade for your rb hoping you have extended crank collar as well?
  • Thanks 1
Purchased Reimax N1 Oil Pump gears (RhdJapan) and Nitto Crank Collar (Goleby Parts) today.
Also will buy full gasket kits for the intake manifold, rocker covers etc. from (Kudos).
Kudos also quoted me $1290 for a CRG T4 High Mount Manifold with 50mm External Gate Port. Still unsure whether I should get 6Boost or CRG. any thoughts?
3 hours ago, oktaytrz said:
Another Question..
In order to fit Nitto Crank Collar, do I have to get the N1 oil pump drive machined to fit?
No you have to get the crank machined to take the collar...pump will fit. And buy the cheapest crank collar you can find...its a piece of steel put through a CNC lathe - not rocket science.
you definitely need to machine it yup..6 boost top mounts are the only manifolds you see in my area and are total bulletproof manifolds that never crack and have a ton of different flange options. 1200 Canadian dollars cant beat it mate.
On 06/03/2020 at 8:36 PM, MoMnDadGTR said:
I literally just went through this with my gtr.  The billet gears are super easy to install. I just used my stock oil pump because of sump issues etc.  I was getting all ready to have an extended nose collar machined on,  to find out that I already had extended nose. 93 and later gtrs all have the extended collar already. I would definitely recommend changing the gears out on the pump as its not the power that destroys them its the rpm. and yeah extended collar forsure if you want reliability.
Mine is a 1993 R32 GTR so I'm guessing I don't have to do anything then? (even though I've purchased nitto crank collar lol)
That's correct unless someone has put an earlier crank in it...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
