I have a 1998 skyline R34 "standard" (GT or GTS) I believe they are called, it is not a gtt, but I would like to put gtt rotors and calipers on it.
if I get a set of good used calipers and rotors would these GTT rotors and caliper components bolt to the stock GT components hub/knuckle etc or would entire caliper mounting hub need to be swapped out to accept mounting of the GTT calipers? also would the current lug bolt pattern be the same so current wheels can be used?
Edited by JC71
https://www.sau.com.au/forums/topic/479908-98-er34-skyline-non-gttgtr-brakes/
1 hour ago, JC71 said:
so from what I can find out, it seems that most agree that If your r34 non turbo car still has the standard GT brakes setup that the brake rotors and calipers from a GTT will bolt right up to the no turbo stock hubs, a few holes will have to be drilled larger to accept the calipers, but sounds like it would work. all agree or any other input?
You do need to drill things to use the GTT brakes.
The R34 GT (non turbo) uses R33 GTST sizing for things. You will be able to directly bolt R33 GTST brakes (front and rear) directly to a R34 GT.
That said, the entirety of "Drilling things" is making one 12mm hole a 14mm hole.
Source: Did this ?
The alternative, and nicer way to do it is to make up replacements for the 14mm inserts on the 310mm 4 pots with a 12mm thread in them. You just press out the big ones and put them in the cupboard, press in the 12mm ones and no drilling required. Just needs someone with a lathe, a tap and a knurler and 15 minutes per insert to make them.
^-- this is also a decent way. to do it. Probably the best way. There's many ways, I just meant to say that some minor work is required to get them to fit due to the different bolt size between GTT and the GT.
This is one of the "GT is just ... lower specced" things, like different ABS system, different bolt on brakes, S15 axles, balbalbala.
You'll most likely get a different answer from each person you ask on this but for me they do bolt straight up.
The R34 GTT brake I got bolted straight up onto my 25GT.
25GT and GTT both used 14mm bolts and even in parts catalogues they use the same bolt being 41005-AA000.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
