Hi all,
Since a while I have a real annoying problem with my 95 R33 gtst. It has a pretty much stock rb25det in it, stock ecu, steel turbo, fmic and a hks ssqv blowoff.
My problem is that when I kick my clutch to stop for a stoplight or sth, my rpm drops down and doesn't catch it in the idle, it just drops further and dies.
Weird thing is, the problem mostly starts when the engine is warm. When I just drive and kick in the clutch, no matter from what rpm it just stalls. When I have been boosting (somewhere in the trip) and I let the engine drop to idle rpm, in gear, and then kick the clutch it will (most of the times) still die. Or it will sometimes drop to 100-200rpm and then tries to get it back to idle but starts bouncing like a mofo.
Sometimes when I haven't been boosting all the time (like, literally no boost at all) it will catch it to idle when I drop the rpm in gear and kick the clutch. (except when kicking clutch from higher rpms 2500+ rpm)
I thought it was maybe a problem of the bov but I'm not that sure anymore.. It's also kinda hard to explain the problem. Anyone knows what it could be???
https://www.sau.com.au/forums/topic/479928-rb25det-dies-when-kicking-clutch/
Its most likely the bov causing your issues. Its dumping out air the MAF has already measured so the engine is getting much less air than what has been measured. The stock ecu isnt good at handling false info. This is a common "issue" with these engines and bovs, especially fake ones. (More a feature really when fitting engines with parts not designed for the setup)
Anyway I think your options are:
1. Get a bypass valve instead of blow off, stock or aftermarket.
2. Block off the bov completely.
3. Go aftermarket ecu with map
4. Relocate maf after bov and get a programmable ecu like nistune with a retune.
5. Ignore the problem and carry on. Learning how to give it gas while braking might help.
I think number 1 is the most sensible one on a stock car, especially since we cant really say for sure its the bov via interweb, but its a good place to start. Stock bov is perfectly fine and should be cheap. I sold mine for ~20€
  • Like 3
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
