Hi all,
Since a while I have a real annoying problem with my 95 R33 gtst. It has a pretty much stock rb25det in it, stock ecu, steel turbo, fmic and a hks ssqv blowoff.
My problem is that when I kick my clutch to stop for a stoplight or sth, my rpm drops down and doesn't catch it in the idle, it just drops further and dies.
Weird thing is, the problem mostly starts when the engine is warm. When I just drive and kick in the clutch, no matter from what rpm it just stalls. When I have been boosting (somewhere in the trip) and I let the engine drop to idle rpm, in gear, and then kick the clutch it will (most of the times) still die. Or it will sometimes drop to 100-200rpm and then tries to get it back to idle but starts bouncing like a mofo.
Sometimes when I haven't been boosting all the time (like, literally no boost at all) it will catch it to idle when I drop the rpm in gear and kick the clutch. (except when kicking clutch from higher rpms 2500+ rpm)
I thought it was maybe a problem of the bov but I'm not that sure anymore.. It's also kinda hard to explain the problem. Anyone knows what it could be???
https://www.sau.com.au/forums/topic/479928-rb25det-dies-when-kicking-clutch/
Its most likely the bov causing your issues. Its dumping out air the MAF has already measured so the engine is getting much less air than what has been measured. The stock ecu isnt good at handling false info. This is a common "issue" with these engines and bovs, especially fake ones. (More a feature really when fitting engines with parts not designed for the setup)
Anyway I think your options are:
1. Get a bypass valve instead of blow off, stock or aftermarket.
2. Block off the bov completely.
3. Go aftermarket ecu with map
4. Relocate maf after bov and get a programmable ecu like nistune with a retune.
5. Ignore the problem and carry on. Learning how to give it gas while braking might help.
I think number 1 is the most sensible one on a stock car, especially since we cant really say for sure its the bov via interweb, but its a good place to start. Stock bov is perfectly fine and should be cheap. I sold mine for ~20€
  • Like 3
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
