Even with the original paint code the colour will never be the same as what you have now due to the age of the car.
This is due to the violets having poor light fastness ( fade easily over time in sunlight due to UV exposure )
There are multiple ways to go about it:
1.   A very competent colour matcher should be able to match the colour of the panels on the car now.
2.  A colour reading can be taken off the panels with a portable spectrophotometer that has the colour formulation data already loaded into it. Then the program can colour match the new formulation match the panel on the car.
You will need to achieve a DE (delta E) of less than 0.3 ( this is the colour reading the spectro will generate ).
Also for it to be a perfect match it will also need to be checked in three light sources : ( all with a DE of less than 0.5 ) :
D65/10 ( what sunlight looks like at midday )
A10/10 ( what sunlight looks like in the early morning )
F2/10 ( what sunlight looks like in the light afternoon )
This is to avoid the colour looking metameric ( different shades of colour at morning/noon/afternoon )
Hows that ? Clear as mud ?
  • Like 1
  • Thanks 1
In the industries Ive supplied into a DE (D65/10) of less than 0.8 would be and acceptable ( targeting the hue line ) match.
A DE (D65/10) of less than 0.5 would be a approved match, again targeting the hue line.
And a DE (D65/10) of less than 0.3, coupled with A10/10 and F2/10, not having a variation of not more 5% between each other always gives the best match where it comes to repairs/matching on older faded colours.
Nothing worse than having the colour come back again cause the customer can "see" a difference and rejects it.
  • Thanks 1
I went to the body shops for repaint some parts, they have spectrophotometer, but they said you must paint all the body of the car to avoid the difference, if you re paint some part you will see the difference, that because this color is different.
I am confused with this problem :44_frowning2:
Sigh . . . . so what they are saying is they couldn't be bothered and all they want is to hit you up for a complete respray.
All that is required with the spectrophotometer is for them to take multiple readings off the body panels.
The colour matching program will average out the results and then generate the formula that is required.
Ive seen this many times over the years with paint places not utilizing their spectros to their full potential.
There are other factors as well but that will involve a bunch of sciency wyencie explanations into the differences in metal and plastic panels
12 minutes ago, r32-25t said:
There is so much pearl in the colour they’ll never get it right
Correct ! Again another issue !
However the macro calculations in the spectro program for automotive colours "should" have pearl inclusion included in it for it to work it out.
Again you then run into the different particle sizes in the pearl suppliers over time since the car was painted originally.
I the end the only way is to use both the spectro and a very good colour matcher for the final visual approval on the car.
I've had my bumper painted due to someone rubbing against it pulling out of a carpark.  I wouldn't say its perfect but pretty unnoticeable - it blends both with the quarter panel and tailight cover.  Only problem now is the fuel marks
  • Like 1
Thanks a lot
so you think, there is a chance or it’s possible to reach the same color perfectly?
What you feel on your car it’s came same color?
How you get the color ? You import it from Japan or the body shop mixed for you ?
how much the Re paint bumper cost you ?
I need to  Re paint rear pumper and side meror and rear light covers
15 minutes ago, PLYNX said:
Yes
Thanks a lot dear that what I need to heart,   I learned too much from you.
any information about this paint, specialy from same one have a lot of experience , or he faced this problem with this color, I will be gratefully
I always notice more than others but its close enough.
The panel beater ordered the paint through their supplier who ordered part of the mix from Nissan (from memory).  The minimum size of whatever came from Nissan had to be 650mL - $495 which was more than enough for my repair.  Total cost for the bumper including a $30 V-Spec decal from Nissan was $1000 4 years ago.
  • Thanks 1
Thanks pro you helping me too much.
any information about this color I need it now, and if have the supplier contact email  or any contact facility send it to me
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
