I have to replace my plenum gasket on an RB25DET, and it looks like I can get either a genuine Nissan gasket, which I believe is flexible rubber, or a Cometic gasket which I think is a more rigid piece, though it's hard to find info. Cometic doesn't list the info. Looks like the original gasket deformed laterally, basically the seals around the runners got sucked in under vacuum. Not surprising since the factory gasket is just rubber. Does anyone have a recommendation, or info mainly on the Cometic gasket?
https://www.sau.com.au/forums/topic/479933-plenum-gasket-replacements/
10 hours ago, zoomzoom said:
Alright, I've got a cometic one on the way. Are the plastic inserts on the plenum reusable? If the cometic gasket is made from a stiffer material, I'm guessing the plastic will crush down more than the gasket.
correct.
