Hi Guys,
I have gone to put front coilovers in my R33 GTR and noticed that the nut at the bottom of the strut just spins on the stud.
Does anyone know if the stud can be replaced or do I have to source myself a new front extension knuckle arm.
Pictures below for reference.
Cheers
Is it the male thread damaged, or the nut? "Just spins" could be either. Nuts are somewhat easier to replace.
The stud is just pressed in. So it can be pressed out. You probably can't buy one, so you'd need to get a machinist to copy it.
Worst case (and this is really really the worst case) you could try cutting it down to the next thread size as a purely temporary fix. I wouldn't do this, but it is something of an option.
It's as if someone has over tightened the nut causing the stud thread to be stripped. The nut does not want to come off, it's just stuck on that spot of the stud spin-able.
The car is still drive-able, I just cant swap in my coilovers.
The nut will have to be destroyed with a grinder and/or nut splitter to get it off. At that point the car will be undrivable until you fix the stud. So either get a replacement upright or plan for it to be off the road while you get someone to remake the part. Your coilovers are off the table until then.
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
