Hi guys, i have weird problem with the 4wd on my R32. Everytime i restart the car in warm condition the 4WD wont work, light in the dash stays on, computer in the rear says error code 18. I tried restarting the engine several times but it keeps staying on. Only after i let the car cool down completely it will go out like its supposed to. I can also hear (or not hear) the pump working when ignition is on/ making this "click" sound every now and then. The oil in the reservoir is at max.
Does anyone of you have an idea on this? How should the front torque gauge behave in general? Mine only starts moving when i go full throttle and goes to about ~5 on the gauge. The car came from japan bout 2 months ago and is afaik mainly stock, no torque splitter etc.
Cheers Max
Edited by Max32
https://www.sau.com.au/forums/topic/479956-bnr32-4wd-attesa-problem/
Find someone with a printer and print off the 800 page manual and study it. Will help you understand your awd system better. I’ve gone through a lot of atessa issues with my car I’ll help out but i suggest using the manual and a good voltage tester. Could save you money from taking to a shop. If you got the cash like gtsboy said take it to a professional and get your car back fixed.
9 hours ago, GTSBoy said:
Owning an R32 GTR without cash these days is just like owning a Porsche 928 without cash. A recipe for a car that never works.
Well yes but some guys have The cash to not even have to diagnose and just drop there car off at a reputable garage. I don’t have a shop within 1000km that knows these cars or do I have lots of cash and my gtr runs great....I take lots of time maintaining it and studying the manual. Don’t need a ton of cash to run a gtr just have to understand it and have some basic tools.
That being said gtsboy you are right you need some good cash to not through cheap parts at the car when it breaks, if you take time and patience and have another daily it’s manageable.
True prices of parts and the cars alone have leaped forsure. Non the less a little passion and time and patience can still go a long way. Don’t have to be rich to own a gtr m8 just gotta enjoy it and build in moderation and not rape the throttle every five seconds. Since I’ve got mine right hasn’t costed me much at all to drive it especially with premium at a crazy low price and this virus all we have to do is cruise ha. Did you ever solve your issue mate.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
