so probably been beaten to death, I apologize.
so in a nutshell for a 30 swap in a r34 GTR. I would need to:
get the awd adaptor
drill a hole for an extra tensioner
and make the crank collar longer?
will the getrag bolt on directly to the motor?
am I missing anything else? Are there instructions on where to drill the hole for the tensioner?
https://www.sau.com.au/forums/topic/479957-2630-build-questions/
Yes, Yes, no necessarily (longer oil pump drive is desirable not required), not exactly (the lower bolt holes will be off between the sump and gearbox by the height of the awd adapter. depending on how much that troubles you I've seen some people just leave the lower bolts out, my gearbox was redrilled for the new lower bolt locations.
The rb30 pdf guide has information on tensioner options, and depending on the block you get you may already have to location for the tensioner machined, or you may need to get that done. There can also be differences on whether the required oil feed and returns are in the block or whether you have to drill and tap them
beyond that, motor prep is like any other rebuild (you can decide how far to go), and things like radiator hoses will not fit directly and will need modification.
And finally, I think it is a terrible idea to put an rb30 in a R34 GTR these days. Start with something people don't care about like a 33 GTR instead (no one cares about middle children).
I had a built rb26 with a t88. Unfortunately dumb shit started to happen and I got the car stolen and it came back with a blown motor and turbo. But I stumbled on a rb30
thank you for the information Do you have a link to the PDF on hand? Or a thread with your build?
2 hours ago, KiwiRS4T said:
Or you could just buy one...(from short block to complete engine)
https://www.ripsracing.com/catalog/Complete-Motors-40/Complete-Engine-Package-32.html
Totally an option if it wasn’t an arm and a leg to ship the motor from there to here. I was looking at a spool short block at one point
  • 11 months later...
1 hour ago, mugiwara no luffy said:
will there be clearance issues with the bonnet and the block.
Some have had issues, I did not (R33).  Mate, custom engine fitting requires an optimistic ' suck it and see approach" my 25/30 went straight in, I could have dicked around for hours making mounts beforehand that would not have been required.
Ah nice. I heard there was no clearance issues but I wanted to make sure.
now to compensate for the extra height I need to modify the down pipe, intercooler piping, and radiator hoses correct?
SOME have had clearance issues, block height is about 20mm higher, my point was you will not know until you check after fitting.
Thanks for the info
I just bought some spacers from prp just in case
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
