Hey all have a few bits and pieces I don’t need and taking up space:
Factory turbos  with dumps(no shaft play)$250
Factory blow off valves $150
Factory manifolds $50
Factory crossover/intake piping $100
Blow off valve piping $50
RB26 cam backing plate $40
3 sets of intakes 1 k&n 1 hks 1 unknown $150
Factory afm x2 $100
All oil, water and wastegate lines including banjos $100
Factory fuel pump good nick $50
Mines ecu $50
RB26 alternator $50
Fuel sender/ top hat unit $20
Charcoal canister $50
R32gtr washer bottle with motors $50n
Nismo fuel reg with standard rail and 11mm raceworks adaptors $150
Factory RB26 camshafts $100
Factory radiator with cut up shroud $70
RB26 sump with cracked diff housing $100
Complete RB26 sump suit rebuild with center and 4.11 gears $250
2 front diff centres $50 each
Front 4.08 ring and pinion $50
Late model r32 gtr 4.11 rear diff $1100
Borg Warner s360 .91 t4 spilt entry made 330awkw on 17psi $500
R32 3inch exhaust with xforce muffler $100
rb26 flywheel with exedy heavy duty clutch $150
Pick up only! Located south east Melbourne
Happy to do bulk deals
Message me on zero447086966 for pictures
Cheers
Edited by Pierreb
https://www.sau.com.au/forums/topic/479964-various-rb26-r32-gtr-parts/
hi mate I would like all the factory water lines, I would forsure add for shipping and your time. im in Canada..pm me if your interested I see some other stuff I would like but may be sold already. one of my stock pieces for the water lines I had to retap cause it was stripped so this would be a god saver!
sorry for the double post by water lines I meant everything you had together there for 100 including oil lines, banjo etc. not just the water lines. cheers m8
  • 3 weeks later...
price updates on what’s left
RB26 factory breathers with -12an fittings $20
Hks intake with k&n filtres $120
RB26 alternator $30
Nismo fuel reg with standard rail and 11mm raceworks adaptors $120
Factory radiator with cut up shroud $50
Complete RB26 sump suit rebuild with center and 4.11 gears $180
Front 4.08 ring and pinion $20
RB26 flywheel and heavy duty pull type clutch exedy fair bit of life left $120
Factory cold side cooler intercooler piping $50
R32 gtr washer bottle with pumps $50
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
