Hey all have a few bits and pieces I don’t need and taking up space:
Factory turbos  with dumps(no shaft play)$250
Factory blow off valves $150
Factory manifolds $50
Factory crossover/intake piping $100
Blow off valve piping $50
RB26 cam backing plate $40
3 sets of intakes 1 k&n 1 hks 1 unknown $150
Factory afm x2 $100
All oil, water and wastegate lines including banjos $100
Factory fuel pump good nick $50
Mines ecu $50
RB26 alternator $50
Fuel sender/ top hat unit $20
Charcoal canister $50
R32gtr washer bottle with motors $50n
Nismo fuel reg with standard rail and 11mm raceworks adaptors $150
Factory RB26 camshafts $100
Factory radiator with cut up shroud $70
RB26 sump with cracked diff housing $100
Complete RB26 sump suit rebuild with center and 4.11 gears $250
2 front diff centres $50 each
Front 4.08 ring and pinion $50
Late model r32 gtr 4.11 rear diff $1100
Borg Warner s360 .91 t4 spilt entry made 330awkw on 17psi $500
R32 3inch exhaust with xforce muffler $100
rb26 flywheel with exedy heavy duty clutch $150
Pick up only! Located south east Melbourne
Happy to do bulk deals
Message me on zero447086966 for pictures
Cheers
Edited by Pierreb
https://www.sau.com.au/forums/topic/479964-various-rb26-r32-gtr-parts/
hi mate I would like all the factory water lines, I would forsure add for shipping and your time. im in Canada..pm me if your interested I see some other stuff I would like but may be sold already. one of my stock pieces for the water lines I had to retap cause it was stripped so this would be a god saver!
sorry for the double post by water lines I meant everything you had together there for 100 including oil lines, banjo etc. not just the water lines. cheers m8
  • 3 weeks later...
price updates on what’s left
RB26 factory breathers with -12an fittings $20
Hks intake with k&n filtres $120
RB26 alternator $30
Nismo fuel reg with standard rail and 11mm raceworks adaptors $120
Factory radiator with cut up shroud $50
Complete RB26 sump suit rebuild with center and 4.11 gears $180
Front 4.08 ring and pinion $20
RB26 flywheel and heavy duty pull type clutch exedy fair bit of life left $120
Factory cold side cooler intercooler piping $50
R32 gtr washer bottle with pumps $50
