3 minutes ago, Semih_Ozdemir said:
I can't choose for example 20k or what not.
Yes....but I already posted that Flukes are autoranging, so you don't have to choose 2k or 20k or any other resistance range. But if it has an Omega symbol on the dial, then it can do resistance. And I cannot imagine a Fluke clamp meter that does not have a resistance range.
So what model is it?
Ahhhhh. Just saw post on previous page.
The continuity range is also resistance. So now we go back to your original reporting on what the sensors were reading. Wait one.
Edited by GTSBoy
You reported no continuity on the 13 - 20 wires. I don't trust that. That would require all of them to be dead. Although you do need to report only the 13-14, 15-16 etc pairs.
Get a resistor of known value from your stash of electronics parts and tell us what the Fluke says when you measure it on the cont/res scale. If you don't have a resistor, get an 8 ohm speaker or something and test that.
The 1-2 and 3-4 pairs were not to be tested up at the ATTESA CU either. They were to be tested down at the sensor plugs. So try that too, and report.
If you don’t have good resistance sin the 8-2.2 range, then measure terminal 1,2,3,4 on the harness side. After this is done we will be able to tell if your control unit is faulty or you have a broken wire or bad ground somewhere . I’m starting to think you should try n find a friends control unit and try it.
Too vague. By "on the harness side", he means down at the sensor plugs. Because the 13-14, 15-16 etc tests are done on the harness side, up at the CU.
I always resist this suggestion until it is proven that there are no other faults on the car that could fry your friend's ATESSA box.
I get Infiniti on both when tested at 3ohms and 500ohms setting
The expected resistance is somewhere between 800 ohms and 2200 ohms. That is why i initially instructed you to choose the 20k range on a multimeter, as it will definitely measure and display those sorts of values.
If you try to measure a resistance larger than the range your meter is set to, it will say infinity. So you have to increase the range.
You got open circuit at 19-20, which is one of the rears. You need to find that 4 pin plug and test those pairs too.
@GTSBoy @MoMnDadGTR
Problem is now fixed.
It was a broken cable inside the driver side foot well. I appreciate you guys for helping out. It was a simplem mistake.
Check your wires for future readers
Cheers
  • Like 1
Good job buddy. I feeel your pain I was in your shoes many times!, little trouble shooting little grunt and some wire chasing and walla!!! I’m curious to know which wire caused this if you can post a pic m8, glad she’s grippin n rippin again!
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
    • So I'm confident in saying its TCS thing. My new cluster I never realized didn't even have bulbs in the TCS or Slip slots. Shining a light through the backside that black plate has nothing for it, unlike my original cluster. Looking at the service manual the only thing that stands out is TCS in relation to the vehicle speed, it has nothing to do with turbos. It sadly looks like I may just need to get the appropriate cluster.
