Hi SAU Community!
I'm just about to join the wider GTR/RB26 ownership and so one of the first things I do, naturally, is join the forums/bbs as a way to find information and inform myself.
Brief car background:
2000-2005: Mk IV GTI (2001)
2003-2005: S13 240sx hatch (1993)
2013-2019: S13 180sx (1998)
2019-current: FD3S (1999)
2020: WGNC34 (2000)
With the exception of the GTI, I have worked on all of these cars myself.  The thumbnail pic is my 180sx which has since been retired.
Looking forward to engaging with you all!!
Cheers
  • Like 1
https://www.sau.com.au/forums/topic/479992-greetings-from-hong-kong/
3 hours ago, PranK said:
Welcome adey.
Any pics of your car(s) ?
I hope all of you in HK are doing ok in these crazy times.
Thanks man! Yea just staying home most of the time.
Now finally have time to start on my engine build :)
DSC_2918.thumb.JPG.6cc65193b0a24db29ecf7bafbebc1b75.JPGThanks @PranK!  Yeah, things easing up a bit here, although recently they've started getting on edge again.  Not nearly as bad as Europe and N.America, though.  Fingers crossed!
Also, hi @etang789
Car photos attached!  WGNC34 coming this summer...
  • Like 2
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
