Predator1 Posted March 19, 2020 Share Posted March 19, 2020 Hi, I've been discussion on and off for BBK options with Brakes Direct. I've bought some pads off them in the past, and I have to say, that they are very responsive and approachable, so big thumbs up to them. Has anyone used their Forza floating rotors at all? They use Alcon calipers which is very impressive too. They offered a Front(365/32 with 6 piston CAR97 calipers) and Rear(335/28 with 4 piston CAR36 Calipers) kit for my 32R and just wondering really if you guys have any feedback on their BBK's at all? Thanks. Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/ Share on other sites More sharing options...
bcozican Posted March 20, 2020 Share Posted March 20, 2020 (edited) I have he brake kit as do many I race with etc The product is good and has been proven Word of warning through experience of myself and many many many people I know I agree they are responsive and approachable and will take your $ but dont expect you order anytime soon or trust any time line they give you. But you get your stuff eventually no matter what they say expect somewhere between 3 - 6 months as they bulk buy etc out of China for some parts they have no control over timelines and given the recent CV there might be more delays / problems also just as a thought Edited March 20, 2020 by bcozican 1 Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7926846 Share on other sites More sharing options...
Predator1 Posted March 20, 2020 Author Share Posted March 20, 2020 Hey thanks for that man. How long have you had that kit on? Thoughts? Does it pull up well on the track? Brake fade? What pads? Do you have the same size kit that I mentioned(365mm fronts)? Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7926847 Share on other sites More sharing options...
bcozican Posted March 20, 2020 Share Posted March 20, 2020 (edited) Been on track about 4 /5 times with it - prob not even reached its potential yet - I went from R34 Brembo with Project Mu 2 piece rotors and H16 03 comp pads to yes the 365mm kit on the front and the Forza 6 brake pads provided with it and significant improved braking - not fade in 3 lap sprint what so ever thats a 1200 kg r32 gtst time attack car doing sprints running brake booster still currently going to peddle box to be able to modulate braking more and will up grade the quality of pads For direct comparison to yours a mate of mine whom I compete against has one/ if not the quickest all round R32 GTR that is still street rego full trim etc and 700hp odd and uses the same but with Project Mu club racer pads I think and more than does the job for a 3 lap sprint Edited March 20, 2020 by bcozican Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7926882 Share on other sites More sharing options...
Predator1 Posted March 20, 2020 Author Share Posted March 20, 2020 Mate that is EXACTLY the kind of info I was after. Did you have to drill the hubs at all? How much work was it to install? Was it actually bolton? I dont care if i have to trim/bend the cover at the back, but I dont really want to drill the hubs out, which is the primary reason for not going with R34 brembo's. Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7926894 Share on other sites More sharing options...
bcozican Posted March 20, 2020 Share Posted March 20, 2020 No drilling of hubs at all. Just specify what you want and they will match it up. All just bolt on im not the most accomplished in the world and took me about 45mins tops to do both Yes backing plates will have to ve gone/ bent/ modded All is good..... once you eventually get the stuff Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7926899 Share on other sites More sharing options...
Kinkstaah Posted March 21, 2020 Share Posted March 21, 2020 Forza is great stuff. It never arrives remotely on time (brakes direct are aware). Pads excellent too. That said, with CV I pretty much on the verge of refunding my purchase (in janurary) with some Raybestos pads. Buy in bulk Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7926954 Share on other sites More sharing options...
Predator1 Posted May 30, 2020 Author Share Posted May 30, 2020 Cheers for the help guys. I ordered the 378mm fronts and 355mm rears. I have a forged 3.2 coming to life soon in my 32R so dont want to be relying on the stock shitutomo's. For comparions sake, I put new oem rotors(4), braided brake lines, new lines and QFM pads, and encountered lots of brake fade in a small circuit.. Lost brakes pulling up from a mere 210k.. Lets hope I dont have to upgrade the BMC. Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7931995 Share on other sites More sharing options...
niZmO_Man Posted May 31, 2020 Share Posted May 31, 2020 which QFM pad? Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7932043 Share on other sites More sharing options...
burn4005 Posted June 1, 2020 Share Posted June 1, 2020 (edited) what calipers did you use for the 355mm rear from brakes direct? I have 380mm fronts with the CR6380 and 350mm 370z rear with stock caliper. looking to upgrade rear to an alcon caliper in future for better balance. pad choice was likely a contributor. put some proper pads and make sure you fluid is fresh and bled. project mu H16 Carbotech XP10/12 performance friction 01/06 etc either flush brakes every event or run Castrol SRF fluid and just bleed a bit to ensure no air. and my rule is double the power, double the brakes. stock brakes on High powered cars doing consecutive laps is a bad idea, so good call on the big kit for the 3.2 Edited June 1, 2020 by burn4005 Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7932110 Share on other sites More sharing options...
Predator1 Posted June 2, 2020 Author Share Posted June 2, 2020 On 31/05/2020 at 8:49 PM, niZmO_Man said: which QFM pad? I'm not sure, It was apparently the top of the link from memory. Either way, not bagging the pads here. Just sharing my experience on the stock brakes. I was running brand new fluid too, bled(inc ABS). On 02/06/2020 at 9:34 AM, burn4005 said: what calipers did you use for the 355mm rear from brakes direct? I have 380mm fronts with the CR6380 and 350mm 370z rear with stock caliper. looking to upgrade rear to an alcon caliper in future for better balance. pad choice was likely a contributor. put some proper pads and make sure you fluid is fresh and bled. project mu H16 Carbotech XP10/12 performance friction 01/06 etc either flush brakes every event or run Castrol SRF fluid and just bleed a bit to ensure no air. and my rule is double the power, double the brakes. stock brakes on High powered cars doing consecutive laps is a bad idea, so good call on the big kit for the 3.2 The fronts are CAR97 and rears are CAR98. What wheels are you running? Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7932198 Share on other sites More sharing options...
burn4005 Posted June 3, 2020 Share Posted June 3, 2020 18x9.5 TE37. The 380mm fit with plenty of room Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7932248 Share on other sites More sharing options...
hattori hanzo Posted June 13, 2020 Share Posted June 13, 2020 Ordered the Alcon BBK from Brakes Direct 3 weeks ago Commited to 6-8 week lead time, I am judging them fiercely. Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7932917 Share on other sites More sharing options...
bcozican Posted June 14, 2020 Share Posted June 14, 2020 On 13/06/2020 at 2:34 PM, hattori hanzo said: Ordered the Alcon BBK from Brakes Direct 3 weeks ago Commited to 6-8 week lead time, I am judging them fiercely. knowing you after all our dramas you'll prob get your ahead of time ! Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7933044 Share on other sites More sharing options...
hattori hanzo Posted June 15, 2020 Share Posted June 15, 2020 8 hours ago, bcozican said: knowing you after all our dramas you'll prob get your ahead of time ! I did drop a long list of names of disappointed by BD while placing my order Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7933097 Share on other sites More sharing options...
Predator1 Posted June 16, 2020 Author Share Posted June 16, 2020 What kit did you order? I got the 378mm front and 355mm rears Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7933572 Share on other sites More sharing options...
sneakey pete Posted June 20, 2020 Share Posted June 20, 2020 On 6/13/2020 at 4:34 PM, hattori hanzo said: Ordered the Alcon BBK from Brakes Direct 3 weeks ago Commited to 6-8 week lead time, I am judging them fiercely. I got told 3-5 weeks back at the start of June so maybe i'll get mine before you get yours... CAR97 and CAR36 calipers with 365/335 rotors however. Still want to run the 17's Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7934177 Share on other sites More sharing options...
Predator1 Posted July 4, 2021 Author Share Posted July 4, 2021 So I decided to put my brakes on, but the dogbones in the front dont clear the knuckles.. Wasnt happy. Did you guys that have 32R's have any issues with the dogbones not clearing? I spoke to Greg who was helpful enough, said to grind off the bit in the corner where it fouls(The dogbone itself). Wasnt too keen on doing that, so will send the dogbones back to them. Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7953655 Share on other sites More sharing options...
hattori hanzo Posted August 23, 2021 Share Posted August 23, 2021 I didn't have any fitment issues, just late delivery. Interesting if they now have fitment issues, possibly new supplier to fix late delivery issues? Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7955021 Share on other sites More sharing options...
numleg Posted August 25, 2021 Share Posted August 25, 2021 Funny story, I had exactly the same experience as Predator1 when I bought my kit from Brakes Direct back in 2015. Constant delays, dog bones didn't fit and supplied bolts were too short. Got the run around from Brakes Direct when trying to sort the issues out. Link to comment https://www.sau.com.au/forums/topic/479995-brakes-direct-bbk/#findComment-7955090 Share on other sites More sharing options...
